transmission problem?
Old Aug 10, 2006 | 08:44 PM
Changvi's Avatar
Changvi
Default transmission problem?
Today as i was driving a bit more aggressive than usual. As i was going from 1st to 2nd, the gear felt like it wants to pop out as i was shifting. It just happened today. I've been reading some of the threads, and some have said that this is a tail tail sign of transmission problem. Is this true? Do you guys think that this might cause a concern? My car is a 03 touring with 26000 miles. thanks....any comments would be helpful..
Old Aug 10, 2006 | 11:18 PM
aren21's Avatar
aren21
Just take it to the dealer and hopefully youll get a fresh transmission!!
Old Aug 10, 2006 | 11:59 PM
Rumbler's Avatar
Rumbler
I was looking at a 2004 Z base model, and when I switched gears it felt like it didn't want to go into the gear smooth. I told the guy , and of course he replied, the car has to be broken in. I just said its got 13k miles, it is broken it, its just broke. And he just said stuff to get my mind off of it so I would just buy a problem, but I didn't. Looking for a more responsible dealer. And better condition Z
Old Aug 11, 2006 | 05:22 AM
MustGoFastR's Avatar
MustGoFastR
It is quite possible that your 1-2 synchro is starting to go; this is the main tranny problem. HOWEVER, with where your tranny is at right now, I doubt very much you'll find any dealer willing to replace it, as it needs to be a noticable, very reproducable problem for them to even acknowledge it's existence (i.e. loud, crunchy grinding on the 1-2 shift). Do you have any of your 4 yr, 60k drivetrain warranty left? At this point, not sure what your options would be, though; you could start driving it real hard and try to get it to the point that it grinds consistently and get it replaced if you have any warranty left, otherwise, you might be buying yourself a new tranny down the road. Hmm, did they extend the drivetrain warranty on '03 cars b/c of this prob, I wonder?
Old Aug 11, 2006 | 11:01 AM
roast's Avatar
roast
There are a few things that can cause it to pop out of gear... but synchros aren't a cause. Synchros just get the collar and the gear spinning at the same speed for a smooth engagement without needing to double clutch. If these go bad you will just have problems with gear engagement; ie grinding.
Popping out of gear could be a linkage problem or worn motor/tranny mounts, which would be the easiest and cheapest to fix. It could also be an internal tranny problem, which would obviously be more involved and expensive.
From you description of the problem it doesnt sound like it's popping out of gear. I'm not sure. "As i was going from 1st to 2nd, the gear felt like it wants to pop out as i was shifting." As you shift, it is supposed to come out of gear, heheh.... can you elaborate any better?
Old Aug 11, 2006 | 02:15 PM
Changvi's Avatar
Changvi
Before this began, when shifting, it was very smooth from 1st to 2nd. But now once in a while, when shifting from 1st to 2nd while clutch is fully engaged, it just wants to pop out by itself without shifting. Hope this helps.
Old Aug 11, 2006 | 02:32 PM
roast's Avatar
roast
Do you mean it pops out of gear when you let off the gas without depressing the clutch?
Old Aug 11, 2006 | 03:43 PM
kevinbonds's Avatar
kevinbonds
I had the same problem to start with. At first it would just not shift smoothly followed by a consistant grind into gear. It's gotten to the point now where i have to slow down and gingerly put it into second or it wont go. New tranny is on the way from nissan. It's been happening since about 5,000 miles now I have 12,000 and its pretty bad. I have and 03. I have been procrastinating on the tranny cause i was waiting to see what direction i was goin with my car that way I could pick out the right clutch. Now its time...
Old Aug 11, 2006 | 04:06 PM
roast's Avatar
roast
kevin what you are describing is not the same problem chang is describing... nowhere did he mention anything about grinding...and nowhere did you mention anything about it popping out of gear...
Am I missing something?
Old Aug 11, 2006 | 07:20 PM
Changvi's Avatar
Changvi
No, when pressing down the clutch and inthe process of shifting from 1st to 2nd. Usually its pretty smooth, but after it just wants to pop out when shifting. But now for some reason is fine. it doesn't show the symptoms anymore...freaking Nissan cars...always play some kind of tricks..
Old Aug 11, 2006 | 07:31 PM
masterj26's Avatar
masterj26
are you talking once you get it into second gear it wants to pop out?
BawlZTT's Avatar
BawlZTT
I have a feeling this is perfectly normal.....
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
