Recall Question???
Old Aug 14, 2006 | 03:32 PM
oman's Avatar
oman
Default Recall Question???
My Z has never had a problem, its an 03 with 39,***.miles
I feel scared taking my z in and have Nissan mechanics tear into it to replace some whack A$$ hose.
Did all of you guys do this? Do some of you guys feel like me and dont feel its necessary because its running fine?
I heard if you dont replace it, the hose can start a fire!!!???
I guess I think that the replacement will go fine but the car will drive or feel diffrent, dont the mechanics have to take the fuel tank out completley?
Old Aug 14, 2006 | 04:14 PM
Built2shredZ's Avatar
Built2shredZ
Some on here are not going to take it in, although most probaby have had it done already... I've only heard of a few problems after the repair was done..
My brother took his in and it still runs fine... I was one of the lucky ones that had a 2004 and didn't need to bring it in for the recall
Make sure you have less then a 1/4 tank of gas when you go in...
Old Aug 14, 2006 | 04:50 PM
The Brickyard Rat's Avatar
The Brickyard Rat
Since it could be a fire issue I think it is absolutely nuts not to have it done.
I had mine done immediately. If you don't trust your dealer find another one.
Mine was replaced without a problem.
Old Aug 14, 2006 | 05:08 PM
Anomaly's Avatar
Anomaly
I got my 04 taken care of. No problems what so ever.
Old Aug 14, 2006 | 05:25 PM
ZmanZZZ's Avatar
ZmanZZZ
you always have to have a dealer that is trustworthy.
Old Aug 14, 2006 | 10:39 PM
KelekonaKustoms's Avatar
KelekonaKustoms
Ive had mine done, no problems
Old Aug 15, 2006 | 03:37 AM
FrankieZZ's Avatar
FrankieZZ
No problem on my '03 either . As a matter of fact , it seems tighter now than before I brought it in .
Old Aug 15, 2006 | 03:52 AM
Brick-Z's Avatar
Brick-Z
I am still up in the air As someone on here already stated, there is about a 1 in 1,000,000 chance your car will catch on fire from the hose however there is about a 1 in 50 chance your car may get screwed up by Nissan.
Old Aug 15, 2006 | 04:28 AM
WYZIWYG's Avatar
WYZIWYG
Brick-Z,
If you wanted to make some aftermarket upgrades to the car where would you take it then? I'd like to get a higher quality brake setup and perhaps get a better exhaust system and thought I'd have these things done at the dealership since I was warned that only the 'special' Nissan mechanics should service my car.
Old Aug 15, 2006 | 06:22 AM
Blue Highways's Avatar
Blue Highways
Default No Flames
A couple months ago I took the Z in for a routine oil change and the Service manager approached me and asked if they could replace the hoses per the recall.
I said "...go ahead..." and not only did I get re-hosed,they topped up my 1/2-full tank with high-test AND washed the car.
All this happened in just two hours,which I spent test-driving a new Maxima and eating all their Krispy Kremes.
Up until then,my Z had never burst into flame,and since then I am flame-free.
Old Aug 15, 2006 | 06:28 AM
Brick-Z's Avatar
Brick-Z
Originally Posted by WYZIWYG
Brick-Z,
Well most aftermarket parts will not be covered by Nissan anyhow. Unless, you go the Nismo route.
Old Aug 15, 2006 | 05:28 PM
JonsilvZ's Avatar
JonsilvZ
At first I was very hesitant on getting the hose recall done. I waited until they got alot of experience. But why risk it? when its done for free? My dealer has done alot of Z recalls. In the end everything was fine and found out the hoses were fine. Build date is Sept 02.
Old Aug 15, 2006 | 05:45 PM
Ztalker's Avatar
Ztalker
its all good.
Old Aug 15, 2006 | 05:49 PM
03performz's Avatar
03performz
I got it done and had the valve thing replaced that caused the fill up prob. No probs. whatsoever. If I didn't get it done it would always have lingered in the back of my mind whenever I would look at the car. So, I had to get it done, plus I can fill up the tank w/ out the pump stopping after 6 gallons .
07ZEKE
Aug 23, 2021 09:15 PM
apex locator
Jul 23, 2021 02:27 AM
issyz
Jul 2, 2017 03:04 PM
