Test Drove First 350Z : Two Problems?
Old Sep 28, 2006 | 01:32 AM
z_stephenson's Avatar
z_stephenson
hehe, there isnt an a4 for the z06, just in a regular c5. but ya... +1 on the z06 if you can get it, it is an amazing car.
In concern with the Z, I would say go back and test drive it but with the TCS/vdc off, whichever is applicable. See if you can get it to reproduce the bouncing while the systems are off. If you can, that is not normal I dont think, and should be though about carefully before deciding to purchase. Good luck with whatever you choose though.
Zach
Old Sep 28, 2006 | 04:45 AM
Kolia's Avatar
Kolia
Originally Posted by iceagetlc
Bouncing tach is normal when riding over small bumps. The tires lose and then quickly regain traction through weight transfer and loss. Not really noticeable unless you stare at the tach, or if it's a moderate sized bump. I see it all the time in 2nd whenever I am on a hilly or rough road.
+1 It's simple physics.
Old Sep 28, 2006 | 05:45 AM
sluggoZ's Avatar
sluggoZ
Just test drive another Z and see what happens!
Old Sep 28, 2006 | 06:06 AM
06Gcoupin's Avatar
06Gcoupin
First of all, a bouncing tach needle is not normal. Im surprised no one has posted this yet, but a bouncing needle is a worn-out clutch. When the needle bounces like that, that means your clutch is slipping. Take that Z for another test drive. Go upto about 35MPH and put it in 6th gear and floor the gas. If the needle jumps around wildly, guess what, that clutch is on its way out...
Old Sep 28, 2006 | 06:16 AM
fowlman01's Avatar
fowlman01
If you have tires that don't match in diameter or highth the slip light will come on ocasionally and you will lose power. As an example when I have my Drag radials on going to the track I have to turn the traction control off or ever once in a while it will cut power. (street tires in front 255-45-17 DR's rear 275-40-17) The car could have had mismatched tires.
Old Sep 28, 2006 | 06:17 AM
pinoyZ's Avatar
pinoyZ
If its a ZR then it is normal for the tach to bounch when the sunlight shinning on the gauge.
Old Sep 28, 2006 | 07:53 AM
kdogg24's Avatar
kdogg24
As for the needle jumping, I would say there may be a problem with it, don't just take the dealers word for it!
The traction control is handy when you want to stay in control. For the times you get the Z on a track, just turn it off.
I considered the S2000, and several other sports cars before I bought my Z. Go drive each of the cars your interested in, and then you will have a better understanding of which car you want. I chose the Z because of the excellent sounding exhaust, awesome handling, powerful engine, killer looks, and many more reasons. Once I drove a Z, it was game over!
etkms
Jun 19, 2022 06:30 PM
lolwatbro
Oct 9, 2021 04:58 AM
350z_z33.
Jul 3, 2017 04:01 AM
FromGtoZ
Sep 20, 2015 03:41 PM
RyansZ33
Sep 15, 2015 05:54 AM
