Z Backfire ??
Old Oct 16, 2006 | 02:06 AM
maXmood's Avatar
maXmood
Under Boost!
Default Z Backfire ??
hey ..
seen lotsa 350z on the street, but only seen 1 that backfires... does it usually happen on stock ?? or do i have to do something to get the backfire??
thnx
Old Oct 16, 2006 | 02:29 AM
HOMiEZ's Avatar
HOMiEZ
just reset your edu to run super rich and let the fire burn baby.
imho backfire is reserved for super high powered race cars, otherwise its just a waste.
Old Oct 16, 2006 | 03:23 AM
Swiffer's Avatar
Swiffer
Doesnt usually happen stock.
Old Oct 16, 2006 | 06:00 AM
06Gcoupin's Avatar
06Gcoupin
Test Pipes can cause that...
Old Oct 16, 2006 | 06:51 AM
InSaNeZ's Avatar
InSaNeZ
In my previous Z, it would backfire whenever I left it in a 1st or 2nd gear and let off the gas to leave the engine slow the car down instead of applying the brakes.
Old Oct 16, 2006 | 10:18 AM
maXmood's Avatar
maXmood
Under Boost!
i need to learn more about it, need to see how it can happen in Z without modding it.. because i'm gonna loose the warranty on my exhaust if i mod it..
anyways, thnx for the reply..
Old Oct 16, 2006 | 12:01 PM
DoktahZ's Avatar
DoktahZ
Its not backfire, its afterfire. Unlit fuel in the exhaust. Backfire is bad for the engine, afterfire is fun. Happens with alot of turbocharged cars since they run much richer than normal.
Old Oct 16, 2006 | 12:07 PM
tekk's Avatar
tekk
if a turbo car backfires a lot, does it mean that the car is not tuned properly? ie its not making as much power as it could?
Old Oct 16, 2006 | 12:46 PM
teknochild's Avatar
teknochild
im not exactly sure about the specifics, but i know one of those is actually good somehow for a turbo, or something, i remember hearing about it somewhere but know nothing about it
who wants to clear it up
Old Oct 16, 2006 | 11:23 PM
Xtrem350Z's Avatar
Xtrem350Z
when i put my injen SES true duals on and my resonated test pipes, i get some fire out of my exhaust when i rev, sounds like backfire, looks like backfire, must be backfire?? LOL, dont know....but i like it
Old Oct 17, 2006 | 05:36 AM
maXmood's Avatar
maXmood
Under Boost!
how to do that ??
Old Oct 17, 2006 | 10:14 AM
InSaNeZ's Avatar
InSaNeZ
It sounds even better in a parking garage or underpass, lol.
Old Oct 17, 2006 | 11:29 AM
bailey bill's Avatar
bailey bill
Turbo cars are likely to backfire if 1) they use an airflow meter and 2) there is a blow-off valve vented to atmosphere. That allows metered air to escape the system, but the ECU still delivers additional fuel for the air that is no longer reaching the engine. Then that super rich charge ignites in the exhaust system.
But this only occurs momentarily, on lift, which is when the BOV vents.
bill
Old Oct 17, 2006 | 11:35 AM
willha418's Avatar
willha418
Let me get this straight... You want your car to backfire? ugh...
Old Oct 17, 2006 | 12:02 PM
maXmood's Avatar
maXmood
Under Boost!
i don't own a Z .. but i've seen 1 that backfires. that's why i'm asking ..
hopefully by march '07 i get '07 Z ...
Old Oct 17, 2006 | 12:45 PM
Spec_Tacular's Avatar
Spec_Tacular
This will be the new brand of RICE
Old Oct 17, 2006 | 03:09 PM
Xoulrath's Avatar
Xoulrath
Turbos cars run rich for two reasons: 1) More air + more fuel = more power. Since most turbos can use all the extra fuel that can be fed to them, they are tuned to run rich for the following reason; 2) by running rich, the excess gas actually cools the combustion chamber, helping to keep detonation at bay.
A non-FI car running rich is not good. It causes you to lose power, not gain. It doesn't really help the engine's longevity either, since most NA's don't run quite that hot.
Old Oct 17, 2006 | 03:20 PM
ArCtM's Avatar
ArCtM
you should hear the 240's with an sr20det swap,almost everytime they let off the throttle you hear a pop
Old Oct 17, 2006 | 08:03 PM
ouch1011's Avatar
ouch1011
Alot of turbo cars (including race cars) are designed to "pop" out the exhaust when they let off the gas in an effort to keep the turbo spooled. The "pop" in the exhaust gives the turbo a little boost of speed, thus making for less turbo lag once you get back on the gas.
Old Oct 18, 2006 | 06:02 AM
DoktahZ's Avatar
DoktahZ
This isnt correct, the turbo has nothing to do with the exhaust at all. Turbo just shoves more air into the engine it has absolutely nothing to do with getting more "pop" or speed from afterfire coming out of the exhaust. Turbo cars just run much richer that is where the afterfire comes from. Extra unburnt gas going into the exhaust and igniting because of the heat.
