Z Backfire ??
Old Oct 18, 2006 | 08:16 AM
ouch1011's Avatar
ouch1011
Originally Posted by DoktahZ
This isnt correct, the turbo has nothing to do with the exhaust at all. Turbo just shoves more air into the engine it has absolutely nothing to do with getting more "pop" or speed from afterfire coming out of the exhaust. Turbo cars just run much richer that is where the afterfire comes from. Extra unburnt gas going into the exhaust and igniting because of the heat.
How can you say that turbos have NOTHING to do with the exhaust?? The are driven solely by the exhaust.
Anyway, read here. Its called anti-lag.
http://paultan.org/archives/2006/06/...firing-system/
Some cars pop out the exhaust like this by accident or due to poor tuning. Others are tuned specifically to do this.
Old Oct 18, 2006 | 02:54 PM
SIRCRASHALOT's Avatar
SIRCRASHALOT
allright i've heard enough the way boosted cars have after fire is due to the fact the as rev's increase so does boost pressure and fuel..... now you can tune your car to handle mad boost and when you turn the boost down or atmospher changes you run rich towards the top of the rev range and when you shift or let off you have fuel running down your hot pipes and it ignites.... now in an n/a car you can do the same but that requires your fuel map to be changed and increased in the higher rev range to protect from over-rev and thus your get your boom(after fire) or you can do it the way i did take out your secondary o2 sensor and run test pipes when the car warms up drive it hard rev match down shift and you can also get the flames........ if you ask me tho its over rated looks nice in a dark canyon that about it.........
Old Oct 18, 2006 | 03:04 PM
hardrock905's Avatar
hardrock905
Originally Posted by willha418
Let me get this straight... You want your car to backfire? ugh...
It's the FF3 curse.
team1320350z
Jul 6, 2008 04:02 PM
tig488
Sep 7, 2006 08:20 PM
nukepharmer
Jul 20, 2006 08:32 PM
tig488
May 26, 2006 06:55 AM
GeoFX
May 22, 2006 12:27 PM
