Help , My Nissan dealership maybe Idiots
Old Dec 22, 2006 | 10:18 AM
Mr. Black's Avatar
Mr. Black
Default Help , My Nissan dealership maybe Idiots
My car is making an roaring, vibrating like noise when i turn left only left. They said it is the tire. So they switched it and told when the nosie would wear away. Well its been about 2000 more miles and its still there. What could this be?
Old Dec 22, 2006 | 10:28 AM
jmunzing's Avatar
jmunzing
Z
I'm not that good with cars as probably most of you are but my first car had something similar to this, except when I turn right.
Try checking the bearing on the side which you hear the noise coming from, it may need to be replaced like mine. (my .02)
Old Dec 22, 2006 | 10:47 AM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
Wheel bearing...
Old Dec 22, 2006 | 10:50 AM
UGOTZ'D's Avatar
UGOTZ'D
def gonna be a wheel bearing if it only happens when ur turning!
Old Dec 22, 2006 | 10:58 AM
6894kevin's Avatar
6894kevin
I love the post title.
Old Dec 22, 2006 | 11:07 AM
JDMFairladyZ33's Avatar
JDMFairladyZ33
If they tell you it's the CV joints going bad on the axles then run...run away fast!!! LOL...sounds like what everybody is say..bearing.
Old Dec 22, 2006 | 11:26 AM
HighwaySpeed's Avatar
HighwaySpeed
Lightbulb
Originally Posted by Mr. Black
Help , My Nissan dealership are Idiots
Bingo!
Go to another dealership.
Old Dec 22, 2006 | 11:31 AM
Theatrix's Avatar
Theatrix
Professional
Bad Wheel bearing on an 06?
Old Dec 22, 2006 | 02:45 PM
Jason@Performance
Performance Nissan
could be the muffler bearings though too... j/k...
Old Dec 22, 2006 | 02:48 PM
JDMFairladyZ33
Could be a plugged con-nooter valve...they tend to make roaring noises when they're backed up Proper flushing will take care of the problem
Old Dec 22, 2006 | 02:52 PM
Ahmads350z's Avatar
Ahmads350z
buy my turbo kit
Old Dec 22, 2006 | 02:55 PM
Jason@Performance
Performance Nissan
Cross drilled brake lines to boot!
Old Dec 23, 2006 | 04:43 PM
kydiwl's Avatar
kydiwl
Default I can relate....
Durham, NC Nissan Dealer
A tech at my dealer told me the headlights can't be adjusted.
The service manager is still swearing the tire roar problem is the tires not the suspension. Even though I have spot on alignment, not craptenza tires, and a tire roar problem.
If your dealer is giving you info you know is not true, or even think is not true, don't even try to argue with 'em...
RUN LIKE HELL!!!
If you know enough to question their opinion, you probably know more about your car than they do.
I know not all dealers are like this, there are some good dealerships out there. Go to another dealer if you can. If you can't, go to my350z.com.
Old Jan 2, 2007 | 08:00 AM
jt14894's Avatar
jt14894
Yep! It sounds like your bearing is starting to go bad.
I have a 2003 and just had the bearing on my right front tire replaced at 36,900 miles. I had noticed this whomping or roaring noise last summer and it just kept getting louder and louder and louder. No matter what speed I was travelling, the noise was always there (unlike the feathering where it occured at low speeds when breaking) and when I would make a left turn, you could definitely hear it roar. WHOMP! WHOMP! WHOMP! WHOMP! WHOMP!!
At first, I thought the noise was a result of the feathering because I did notice that the right front tire showed wear on the inside tread. The left front wasn't bad so I had both front tires replaced, anyway, and the alignment redone, but it still didn't get rid of the noise.
It took me some time to figure it out, but then I suspected it was the bearing so I took it to my local 350Z club member's shop and he confirmed it.
Apparently, the seal had gone bad and the grease had seeped out thus causing the noise which I had been hearing.
He got a new replacement part, installed it, and now the noise is completely gone!!! WOO HOO!!!
It had been a long time since I heard nothing, but the sound of the a quiet ride.
I can actually hear a pin drop.
Have it checked ASAP.
If you know a local shop, take it there, otherwise to the dealer.
Old Jan 2, 2007 | 01:25 PM
3000ways2break's Avatar
3000ways2break
Originally Posted by Ahmads350z
buy my turbo kit
Hahahaha!
sales@czp
Sep 23, 2019 03:30 PM
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
Cashwin
Oct 1, 2015 06:36 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
