Introducing.....the 2007 350Z with the VQ35HR :)
Old Jan 19, 2007 | 09:30 PM
  #101
hiz-n-herz's Avatar
hiz-n-herz
Originally Posted by camaro194
Thanks for the pics!
Whats up with that silver trim piece by the interior door handle? Doesnt seem like it belongs.
I think that's a just white plastic sticker to keep that panel from getting marred before delivery. They left those on my 06 when I picked it up...
Old Jan 19, 2007 | 09:33 PM
  #102
GOITOMGOOSE's Avatar
GOITOMGOOSE
damn i just can't stand the hood
Old Jan 19, 2007 | 09:42 PM
  #103
Rosko's Avatar
Rosko
Originally Posted by hiz-n-herz
But that's what happens whe you take a transversely-mounted (FWD) engine from the altima/maxima, rotate it 90 degrees and and shove it into a RWD car. Talk about half-assed. Dipstick in the 06 and older has to be the car's single worst feature
The VQ35 wasn't designed to be transverse mounted specifically. It first appeared in the Pathfinder - not a FWD vehicle. If I had to hazard a guess, I'd say Nissan designed it knowing full well that it would be used in RWD, FWD and 4WD vehicles before they ever put pencil to paper. In fact, if you add up how many FWD vehicles vs how many RWD vehicles use this engine, you'll find that the ratio is about even.
Old Jan 19, 2007 | 10:21 PM
  #104
hiz-n-herz's Avatar
hiz-n-herz
Damm dude, you know your VQ35... So that dipstick under the air intake tube was intentional? Looks more like an "Oh ****, we forgot about a dipstick!" design...
The E36 M3 dipstick is a 12-gauge picece of straight metal with a plastic measuring thing at the bottom. No muss, no fuss. I might go check out an 07 z just to see the dipstick! That might be enough to sway me to an 07. That and no pinging...
Old Jan 19, 2007 | 10:23 PM
  #105
InSaNeZ's Avatar
InSaNeZ
Old Jan 19, 2007 | 11:29 PM
  #106
itburns's Avatar
itburns
Originally Posted by Eddie@Performance
Yes that is correct. Even though it only makes 6hp more then its predecessor the new HR motors feel like a different beast, i drove a G35 that had the new VQ35HR and that thing was a mover...imagine a much lighter 350Z with the same powertrain....hehe only gets better
Do you believe that the new G35 with the new HR engine would be able to whip an 04.5 Z w/a Nismo exhaust (drivers are of equal skill)? This would be totally unacceptable to me!
Old Jan 19, 2007 | 11:40 PM
  #107
itburns's Avatar
itburns
Originally Posted by Formulajon
Yeah that is wierd. I just noticed that too after you said it. The Tach is in the middle of the component cluster. Good find there.
Hey guys! Trip out! The 07's have two tail pipes in the back of the car instead of just one. Did anybody else notice? Err, that must be a Track model in the pikchurs.
Old Jan 20, 2007 | 12:20 AM
  #108
gsazabi's Avatar
gsazabi
According to automobile magazine stats for base model:
DIMENSIONS:
Wheelbase: 104.3 in
Length: 169.8 in
Width: 71.5 in
Height: 52.1 in
Curb weight: 3335 lb
C/D TEST RESULTS:
Zero to 60 mph: 5.6 sec
Zero to 100 mph: 14.6 sec
Zero to 140 mph: 34.4 sec
Street start, 5-60 mph: 6.2 sec
Standing ¼-mile: 14.2 sec @ 99 mph
Braking, 70-0 mph: 160 ft
Roadholding, 300-ft-dia skidpad: 0.93 g
I hope that's numbers for the 06 because otherwise it's dissapointing.
07 G and Lexus IS350, which has same hp and more weight than the Z, tested for 0-60 time of low 5's.
Old Jan 20, 2007 | 12:23 AM
  #109
zand02max's Avatar
zand02max
Old Jan 20, 2007 | 01:43 AM
  #110
RICHAZN's Avatar
RICHAZN
For those of you wanting to possibly swap manifolds...
I dont think it will be easy as the ecu would have to be programmed for 2 TB, 2 MAFS, and you will need a upper and lower collector since the collector flange looks totally different. Probably not worth the swap....who knows.
all you have to do is hook up a HKS VPC type of electronics to the engine... this way you can run without an MAF... but hey thats me... if i get this car though however i may just be able to put the new popcharger kits out on the market first... i am a machinist after all... but i need to find someone to take my tundra for a half decent price
Old Jan 20, 2007 | 03:37 AM
  #111
krismax's Avatar
krismax
I was just reading a comparo in road & track mag with 07 G35 sedan.
they say the HR has a 7500 rpm redline but a 7800 rpm fuel cut if this is true then thats nuts!!!!
Old Jan 20, 2007 | 04:27 AM
  #112
aleok's Avatar
aleok
anyone know the benefits of having the intake manifold ports square shaped? has anyone opened up the plenum and looked inside?
Old Jan 20, 2007 | 04:38 AM
  #113
Minda's Avatar
Minda
Color is really nice. Hood is not that bad.
I wonder whether the new hood can be fitted for 03-06, also whether Stillen SC would fit under this new hood on 03-06?
Old Jan 20, 2007 | 04:43 AM
  #114
Minda's Avatar
Minda
Default Headers on new VQ35HR?
Also, does the new engine use equal lenght headers? It would be fun to retrofit them on the older engine.
Old Jan 20, 2007 | 05:01 AM
  #115
Spec_Tacular's Avatar
Spec_Tacular
Originally Posted by zand02max
Next time leave the smarta$$ comments to yourself!
They normally come in multiples at that dealership, so SU NOOB!
NOOB?? I have been selling Nissans for 3 yrs.
Old Jan 20, 2007 | 06:38 AM
  #116
Diesel350's Avatar
Diesel350
DIMENSIONS:
Wheelbase: 104.3 in
Length: 169.8 in
Width: 71.5 in
Height: 52.1 in
C/D TEST RESULTS:
If that is true I can't wait to smoke some 07's!!
Old Jan 20, 2007 | 07:16 AM
  #117
Tenac1ousZ's Avatar
Tenac1ousZ
DIMENSIONS:
Wheelbase: 104.3 in
Length: 169.8 in
Width: 71.5 in
Height: 52.1 in
C/D TEST RESULTS:
Those performance numbers sux to the power of 10 -- I'm hoping that's a mistake of some sort by C/D. I'm sure the VQhr has more potential in the n/a aftermarket than both the current VQ's, but in stock form, it looks really bad Where is the light-weight, non-couch potato version of the Z? There should be a no-radio, no-rear carpet, no-anything-that's-related-to-luxury version. I would buy that in a heartbeat.
By the way Eddie, could you please film the new engine reving and driving around for us? I wonder what it sounds like.
Old Jan 20, 2007 | 07:30 AM
  #118
SargentZ's Avatar
SargentZ
Yeah, from other pics, it is front and center and even appears to be a more of a straight shot to the oil pan. It takes at least 15 mins and 15 tries to get an oil level reading on my 06. Worst design ever And I have been wrenching on cars for 20 years...
Oh ****, I'm not the OP...
Sounds like they finally got it right for the 07 then. Kudos Nissan, glad I waited and still waiting "patiently" for the new model.
SZ
Old Jan 20, 2007 | 08:17 AM
  #119
350Zteve's Avatar
350Zteve
Do they come with the true dual exhaust now like the G?
Old Jan 20, 2007 | 08:32 AM
  #120
Z04's Avatar
Z04
i think i can get past the looks fo that hood, only if it is in that sexy blue
