Some good 07 engine information
Old Jan 19, 2007 | 05:08 PM
boomer gt's Avatar
boomer gt
Default Some good 07 engine information
http://tinyurl.com/yva7fg
Old Jan 19, 2007 | 05:15 PM
zand02max's Avatar
zand02max
Originally Posted by boomer gt
http://www.*********.com/zwiki/VQ35HR_Presentation
sorry if it doesn't link by mouse.
We're not mind readers, care to fill the *************************************** in?
Old Jan 19, 2007 | 08:06 PM
mthreat's Avatar
mthreat
Yes: http://tinyurl.com/yva7fg
Old Jan 19, 2007 | 08:51 PM
daz311x's Avatar
daz311x
slide 37 says it accelerates to 60 mph one second faster!!
Old Jan 19, 2007 | 09:02 PM
hiz-n-herz's Avatar
hiz-n-herz
repost... But I'll comment anyway cause I hate the repost police...
They say the ENGINE does. It does it in the 07 G35 coupe, with the help of a shorter final drive, which the Z will not get. No idea why! Z will prolly be .2 seconds quicker to 60, which means the G35 coupe will still be faster than the z. G35 owners spend more $$ on their cars and prolly expect to be faster. I have no idea...
I think Nissan will some out with a supercharged or twin turbo version on the new HR engine... Why else the stronger bottom end? Why no lower final drive? What is the mystery model that has not come out yet?
Old Jan 20, 2007 | 04:54 AM
boomer gt's Avatar
boomer gt
Sorry I cut and pasted and went to bed without checking. Wasn't sure if it would be direct link. I guess the paste dried and left some ****** behind. LOL
Mthreat..thanks for the quick fix!!
Old Jan 20, 2007 | 02:48 PM
RBlover69's Avatar
RBlover69
i doubt the g 35 coupe with the HR will be faster stock then the Z HR. That doesnt make any sense considering it will also weight more. lmao. It will be the same ratio as the current Z and G with the Z beating just out of sheer weight. There not going to make there flag sports car slower then there flag sports coupe. i
Old Jan 20, 2007 | 02:51 PM
RBlover69's Avatar
RBlover69
i meant faster stock in the G coupe the the Z stock both fitted with Hrs.
Old Jan 20, 2007 | 02:58 PM
Stanky19's Avatar
Stanky19
that seems like someone at nissan just altering graphs to make their boss happy. 6 more hp than the current Vq motor, is not going to make 1 sec. 0-60mph improvement. Unless the tourque curve changes drastically, it's a bunch of overhyped big words.
Old Jan 20, 2007 | 03:06 PM
Ilov350ZEE's Avatar
Ilov350ZEE
its not only 6 hp more like 15-20hp. The 306hp from the HR motor is rated under the new SAE hp rating, if you convert that to the old rating i'll be around 315-320hp. Get it?
Old Jan 22, 2007 | 07:08 AM
rockinbboy's Avatar
rockinbboy
+1. Most people don't realize the new power rating is under the new SAE rating.
Old Jan 22, 2007 | 09:53 AM
RBlover69's Avatar
RBlover69
i wonder what the REvups and previous Zs would rate under the sae ratings.
Old Jan 22, 2007 | 10:05 AM
rocks's Avatar
rocks
They probably rate the same as they did before. What is the lift of the cams in the HR?
Old Jan 22, 2007 | 10:21 AM
jeeper78's Avatar
jeeper78
It all depends on how much the numbers were fudged. The new system is just designed to eliminate the fudge factor, or "eliminate subjective interpretation in establishing horsepower claims".
Old Jan 22, 2007 | 11:55 AM
RBlover69's Avatar
RBlover69
so what about dyno jets using sae ratings, would those be a accurate tool . I always wondered what the industry used to dyno there products .
Old Jan 23, 2007 | 06:13 AM
jeeper78's Avatar
jeeper78
The ratings you see on car spec sheets, I believe are supposed to be SAE net horsepower. This is measured at the flywheel, on an engine dyno, and the engine is tested with all accessories installed, including a full exhaust system, all pumps, the alternator, the starter, and emissions controls.
Old Jan 26, 2007 | 05:35 AM
ZmanZZZ's Avatar
ZmanZZZ
oooh ok, horsepower differential
liqalu04
Jan 2, 2022 12:58 PM
Jambo016
Sep 16, 2016 01:08 PM
Dymsi
Sep 29, 2015 11:32 AM
