Thump sound?
Old Feb 17, 2007 | 07:12 PM
Zya123's Avatar
Zya123
Default Thump sound?
Im not sure if this is normal but when I am about to put the car into 1st gear, It will make a thump sound, It only does that sometimes, is that normal?
Old Feb 17, 2007 | 07:36 PM
Escobar's Avatar
Escobar
be more specific
Old Feb 17, 2007 | 11:29 PM
FALLEN1z's Avatar
FALLEN1z
if what's happening is what it sounds like to me me it sounds like your clutch may not be disengaging all the way. on my last car the clutch was screwed up and when i had the clutch in and i went to put it in first it was a fairly audible thump sound. it was because since the trans wasnt disengaging all the way, putting it into gear caused the drivetrain from the clutch back to shift a little bit
Old Feb 18, 2007 | 06:54 AM
Zya123's Avatar
Zya123
So I guess if it gets worse ill bring it to teh dealer, do you know if something like that is covered by the warrenty?
Old Feb 18, 2007 | 11:15 AM
FALLEN1z's Avatar
FALLEN1z
i dont think the clutch is covered but if it screws up the trans i know your supposed to get a new clutch with your first trans replacement. unless somehow they determine that it was your fault i think it would be warranteed then ....
Old Feb 18, 2007 | 12:36 PM
Tenac1ousZ's Avatar
Tenac1ousZ
That thump sound is most likely the drive shaft moving and engaging with the final drive/differential as you put it into gear.
When you step on the clutch, your gear is still spinning slightly from rotating momentum, and when you put it into gear, the sychronizer hook-up the drive shaft with the slowly-spinning gears, which causes the drive shaft to turn slightly, resulting in that thump noise.
Try clutching in, wait about 2 seconds (to let the gears stop spinning), then put it into 1st - you won't hear that thump. I've heard that on new and old cars, including my Z when new. It's normal. But if it gets worst, take it to a dealer for inspection...
Old Feb 18, 2007 | 12:42 PM
roast's Avatar
roast
Select 2nd gear OR double clutch before selecting first gear.
Obadabot
Jun 18, 2023 11:31 PM
sales@czp
Sep 23, 2019 03:30 PM
wanderingstuden
Jan 28, 2016 07:03 PM
Justin100
Nov 29, 2015 03:58 PM
samansharif
Sep 25, 2015 12:31 PM
