anyone here know how shift w/ out using the clutch???
Old Apr 11, 2003 | 02:05 PM
OP Z's Avatar
OP Z
Ask this guy.
https://my350z.com/forum/showthread....threadid=24839
Old Apr 13, 2003 | 05:05 PM
zogan's Avatar
zogan
Originally posted by OP Z
Ask this guy.
I barely drive my car hard, and I am going to have a new tranny installed wed. Nissan is aware of the problem, just havent said anything public (i think). Its the clevis/clovis (sp?) that is bad, and there is a chance that it damaged the tranny, so they replace both to be safe.
Old Apr 18, 2003 | 04:35 AM
cotmfk's Avatar
cotmfk
What does that part do? What is it's function?
Old Apr 18, 2003 | 11:45 AM
Inova's Avatar
Inova
GUYS!! you MUST try this!!!
i was a bit skeptical at first when i read the z is easy to shift without the clutch. i tried it today and i was so surprised that it actually worked VERY WELL!! the ONLY trick is that you have to match the rpm after the shift. for instance, if i pull the gear out of 2nd to go into third, i just easy the shifter out and then wait about .5 sec and then slide it into 3rd. it works so well!! NO GRIND OR ANYTHING!! omg i am so extatic right now that i finally know to do it. if u let the rev drop too low just gas it a little and the gear will slide in itself. TRY IT!!
Old Apr 18, 2003 | 12:12 PM
ares's Avatar
ares
Veteran
and if they drop to low does it gring before sliding in? as long as race cars continue to use a clutch when shifting, I will too. not including clutchless manuals, they still keep the clutch even tho assuredly the computer could perfectly match revs for them.
Old Apr 18, 2003 | 05:18 PM
zogan's Avatar
zogan
don't know, thats a good question though
Old Apr 18, 2003 | 05:20 PM
zogan's Avatar
zogan
I tried it too on the Z, it is amazing how easy it is, there is no grind at all, its like it won't let you grind. You rev it up a little, and when it gets to the right rev, it allows you to place it in gear, 2nd real easy, third easy-but you must even it right after you pop it in gear.
Old Apr 20, 2003 | 06:15 AM
cotmfk's Avatar
cotmfk
Oh well! Anybody know?
Old Apr 20, 2003 | 09:17 AM
zogan's Avatar
zogan
I have started a thread in the problem maintence section and ask those guys, a lot of them know their stuff real well. I hope we get some answers
https://my350z.com/forum/showthread....threadid=26702
sherm
Apr 11, 2020 05:21 PM
