Does your gas cap door fit flush wit body
Old Apr 10, 2003 | 06:01 AM
ZRiCaN's Avatar
ZRiCaN
Question Does your gas cap door fit flush wit body
I dunno if anyone else has this problem but when I close the door to the gas cap it doesnt sit flush with the body, you can push it flush but it pops right back. And having the blue one and since the gas door sits at a different angle than the body producing an appearance of a different shade of blue when looked at from behind. i dunno anyone else have this problem and is there a way to fix?
Old Apr 10, 2003 | 06:03 AM
del105's Avatar
del105
15 f125
I opened mine and bent it by hand until it was flush it is perfect now.
Old Apr 10, 2003 | 06:09 AM
ZRiCaN's Avatar
ZRiCaN
thanx
Old Apr 10, 2003 | 06:23 AM
ares's Avatar
ares
Veteran
Im just waiting for someone to make it out of metal or CF, anything with more strength than plastic. and a better fit.
Old Apr 10, 2003 | 07:43 AM
ZiggaDigga's Avatar
ZiggaDigga
Mine sticks out a little at the bottom but it's not bad enough to really bother me.
I do wish it was made out of metal though, it just seems kind of cheezy to have it made out of plastic....
Old Apr 10, 2003 | 08:29 AM
SunsetZ's Avatar
SunsetZ
Someone mentioned that the problem for some people was that they were not putting the plastic cord attached to the cap behind the metal tab at the lower right side of the opening.
Old Apr 10, 2003 | 08:41 AM
Tisha's Avatar
Tisha
Mine is flush, but a little off center. It bugs me.
Old Apr 10, 2003 | 10:35 AM
k2we's Avatar
k2we
SunsetZ is right.. You have to make sure the plastic cord that holds the cap is tucked away in a certain position. I had the same problem but I now make sure the tie is positioned behind the metal tab and the cover looks perfect. Give it a try BEFORE you start bending the bracket..
Steve (k2we) Dobbs Ferry, NY
Old Apr 10, 2003 | 10:39 AM
350zSpeedRacer's Avatar
350zSpeedRacer
I've never had a problem with mine. It's a slightly different shade of DB, but I already knew that was going to happen.
Old Apr 10, 2003 | 11:41 AM
Z4KR's Avatar
Z4KR
I just noticed this as well on my last fill up. I'll check to see if the cord is getting in the way of the metal tap. Thx!
Old Apr 10, 2003 | 11:46 AM
del105's Avatar
del105
15 f125
I'm telling you with slight pressure you can make it fit exactly just try to bend the entire thing with your hands. Not to hard obviously but constant pressure for about 30 seconds in the proper direction will fix this permenently.
Old Apr 10, 2003 | 11:50 AM
SunsetZ's Avatar
SunsetZ
The only problem I have had is pushing the open button and the door not opening. Seems to take a couple of times for it to pop open. Any suggestions for increasing the force on whatever pushes the gas door open?
350Z_Al
Oct 29, 2020 07:44 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
