Me vs. my friend (Who is stupid?)
Old Apr 27, 2007 | 09:04 AM
MustGoFastR's Avatar
MustGoFastR
Cool. I'll have to try and make a point of trying it both ways to see which works best for me; it's always just been more intuitive to blip, then shift for me... Once the clutch is engaged, though, blipping should have no bearing on what happens inside the tranny or shifting and it just makes sense to me that the little extra time the tranny has to spin down while you blip first would help synchro wear and gear selection...
Old Apr 27, 2007 | 09:15 AM
Spoolin Z's Avatar
Spoolin Z
You ready for this kids?
But double clutching adds a third step into the mix. The shifter, rather than going straight to the next gear, makes a stop in neutral and then the clutch is released. This is to allow the engine to slow down (or with a tap on the gas, speed up when downshifting) so the transition into the next gear is much more smooth. The driver then depresses the clutch again and completes the shift into the target gear, and finally the clutch is released again, putting the car back into gear. It only takes a split second for the engine speed to match the speed of the gears, so the entire action is done very quickly as a fluid sequence of events.
source - http://www.wisegeek.com/what-is-double-clutching.htm
in order to downshift, engine RPMs must be increased while the gearbox is in neutral and the clutch is engaged. This requires the driver to shift into neutral, release the clutch pedal, apply throttle to bring the RPMs up to a suitable speed, depress the clutch pedal again, and finally shift into gear. This operation can be very difficult to master, as it requires the driver to gauge the speed of the vehicle accurately.
source - http://en.wikipedia.org/wiki/Double_declutch
For those of you who can't read, here's a nice video http://video.google.com/videoplay?do...88575741675515
I can come up with these sources all day....
The truth of it is that double clutching is NOT necessary (like I said before) as this is the job of the syncro. However, if you want to make your syncros last longer and have smoother downshifts double clutching is the way to go.
Just because I'm a new member here it doesn't mean I haven't owned/raced fast cars in the past. And there's so much wrong with the F&F I don't even know where to begin. Nothing tops the floor panel falling out of the eclipse for no reason at all. Why it was even there to begin with is an even better question.
Old Apr 27, 2007 | 09:17 AM
Vorais's Avatar
Vorais
Double clutching is useful for worn out trannys, very old cars, semi's, and some of the older/cheaper race cars.. For people that are wearing out their syncros in 75k miles, what the hell are you doing to your car? I have owned many cars and have gone through a lot of clutches, but only once ever needed to replace the syncros (and that was on a heavily abused car that was on it's second clutch during my ownership.)
Old Apr 27, 2007 | 09:22 AM
bboypuertoroc's Avatar
bboypuertoroc
Originally Posted by Spoolin Z
1. Press in the clutch
2. Select neutral
3. Release the clutch
4. Blip the throttle
5. Press in the clutch
6. Select the gear
7. Release the clutch
You don't need to put in neutral. All you need to do is press/hold clutch, rev match while downshifting, release clutch. Why double-clutch it? Double clutching is for cars without synchros/worn synchros and the F+F crowd.
Blu_Blur's Avatar
Blu_Blur
Originally Posted by Fluid1
Wrong. Clutch is pressed in only once, new gear selected, throttle blip, released. That's what I do road racing.
+1
Unless the synchros are being affected somehow WHEN the clutch is still depressed, it is an utter waste of time to do that double clutching crap.
Single-clutch-press downshifting FTW!
Old Apr 27, 2007 | 09:23 AM
Blu_Blur's Avatar
Blu_Blur
Besides, a perfect rev match will utilise very little of what the synchros do anyways, right? As long as there is no lurch and surge after the shift, you are doing the tranny a favor.
Old Apr 27, 2007 | 09:37 AM
Spoolin Z's Avatar
Spoolin Z
Synchros wear out after lots of regular downshifting. I used to own a mint 93 dodge stealth twin turbo. http://people.umass.edu/dthornic/pho...lth%20(13).jpg It drove like it did from the day I bought it to the day I sold it. I drove a bunch of other peoples 3000gt/stealths while I owned it and a good amount of them had grinding gears and less miles on their cars than me. I went for a ride with most of them and could see that it was from their driving style. Most of them downshifted every time they came to a stop and did not rev match. Some did crude rev matching and still had problems. I've witnessed it first hand.
Honestly, I don't really care how you guys shift and most of you won't experience worn syncrhos in your time of ownership, since these cars are still very new. However 7-10 years down the line, double clutching will make a big difference in how your tranny will shift.
Old Apr 27, 2007 | 09:42 AM
bboypuertoroc
Like I said, double clutching is for cars with no/worn synchros and the F+F crowd.
I ALWAYS rev-match... it's second nature to me along with heel-toe shifting. I do it every day so when I actually need to (touge or auto-x) I don't need to think about it... it just comes naturally.
Old Apr 27, 2007 | 09:43 AM
Spoolin Z's Avatar
Spoolin Z
"The purpose of the double-clutch technique is to match the rotational speed of the input shaft being driven by the engine to the rotational speed of the gear you wish to select (directly connected to rotating wheels)."
Rev matching by just blipping the throttle while shifting to the lower gear will only increase the engine speed to the rotational speed of the gear you want. It will not increase the speed of the input shaft because the clutch is disengaged. This is where your synchros will come in and match the revolutions for you. But just like your clutch, they will wear out over time.
Old Apr 27, 2007 | 09:44 AM
coreapoc's Avatar
coreapoc
You can come up with sources all day Spoolin but since Wikipedia is openly editable by the public, Ill stick to my own theorys.
Old Apr 27, 2007 | 09:46 AM
JCat's Avatar
JCat
I drive my -Z- like I stole it. Perhaps that is why the local Nissan -Z- dealer is currently installing tranny #5 in my car.
My advice.........baby the -Z- tranny if you don't want to have it replaced every 7.5 months.
Old Apr 27, 2007 | 09:53 AM
Spoolin Z's Avatar
Spoolin Z
The synchros become worn because of a lack of proper double clutching. At this point, you will have to start double clutching or your gears will grind on every shift and eventually strip.
Here's more reading for you http://www.triumphspitfire.com/healtoe.html
Proper heel-toe technique includes double clutching.
The reason you believe you think your fine by just doing a simple rev match is due to the fact that your synchros are making up for the slower input shaft speed for you. (as they are designed to).
I've yet to see anyone else post a source showing that simple revmatching downshifting will not cause wear on the synchros.
Like I said before, most of you won't see the bad effects of non-double clutching downshifts in your time of ownership. Just like most of you will not have to replace the original clutch (if you're stock). So you don't really have to worry about it. I was just correcting the OP because both he and his friend are wrong.
Old Apr 27, 2007 | 09:56 AM
Spoolin Z's Avatar
Spoolin Z
I agree that wiki is a poor source, however if you click on the sources below like I did, you'll see that that wiki summary is very accurate.
Just google "double clutching" and you'll see what I mean.
I'm surprised so many of you are so set in your ways and too stubborn to even read about how to put less wear on your synchros. But whatever, its your tranny, not mine. Mine will shift like butter for its entire life, much like my stealth did.
Old Apr 27, 2007 | 10:13 AM
coreapoc's Avatar
coreapoc
Ive yet to have problems with my current, and if I get a Z it will be under factory.After that I would probably lean towards a getrag anyways.
Old Apr 27, 2007 | 10:18 AM
bboypuertoroc
Good info Spoolin Z... it does say in there that it's more for older cars though.
My tranny will be built before my synchros go bad anyways, so even if it DOES wear down the synchros I'll be fine.
Old Apr 27, 2007 | 10:22 AM
djnc's Avatar
djnc
i downshift to 3rd and brake until i get to 18mph or so, then switch the neutral...i figure it puts less pressure on the brakes and its not a ton of shifts to screw up the trans
Old Apr 27, 2007 | 10:33 AM
MustGoFastR
Ugh... that's a whole other can of worms...
Old Apr 27, 2007 | 10:35 AM
  #38
Spoolin Z's Avatar
Spoolin Z
If you plan to rebuild anyway you can go crazy
Happy to see at least one person listen.
Old Apr 27, 2007 | 10:37 AM
  #39
Spoolin Z's Avatar
Spoolin Z
I do the same.
I'll spend $50 and an hour of labor putting on brake pads vs putting on a new clutch, resurfacing my flywheel and possibly replacing synchros anyday.
Old Apr 27, 2007 | 10:38 AM
  #40
steve5's Avatar
steve5
granny shifting FTW F&FFTW
