Shifting
Old May 24, 2007 | 09:37 AM
  #41
ZULATER06's Avatar
ZULATER06
Smashing in a back of another car was freakin hilarious
Old May 24, 2007 | 09:39 AM
  #42
VitViper's Avatar
VitViper
Originally Posted by MJM Z
Very helpful, thanks. Just curious though, why put it in 2nd, then 1st? Why not just right into 1st? I'm sure it accomplishes something, what is it?
Aligns the syncros for an easier/smoother shift to 1st. This is more noticable on crappy trannies (like the ones Ford puts into their econoboxes, boy was my ZX2 a pain in the @$$ to get into 1st).
Old May 24, 2007 | 09:57 AM
  #43
NGZ's Avatar
NGZ
I upshift and downshift along with my speed. I don't go all the way down to 2nd gear (unless cornering), but I like to heel-toe 6->5->4->maybe3 smoothly down to a stop. For some reason I feel really nervous coasting in neutral.
As far as wear on the tranny, I'd say if you're doing it right it's about as much wear as upshifting.
Old May 25, 2007 | 08:48 PM
  #44
roast's Avatar
roast
Originally Posted by smartparts15
Don't own a Z.... yet.... 01 eclipse GT, All that I was saying is its more fuel efficient to put it in neutral and every time you use your cluth it still causes wear on the throwout bearing/tranny/clutch, but by all means do what you like to do, if you enjoy down shifting go for it, where I live now there is no one to impress usually, just empty roads, which are fun... but really its pretty much personal preference.
Not true. It is less fuel efficient to coast in neutral. When you're in neutral, gas is being supplied to keep the engine turning. When engine braking, the fuel injectors are closed because no gas is used/needed to keep the engine turning. There are several ways to prove this to yourself if in doubt.
Old May 25, 2007 | 11:43 PM
  #45
GG06Si's Avatar
GG06Si
^wth, the engine is always on and the injectors are always working
Old May 25, 2007 | 11:56 PM
  #46
roast's Avatar
roast
Oh yeah? Prove it.
Old May 26, 2007 | 12:12 AM
  #47
Z_Driver's Avatar
Z_Driver
Master
Originally Posted by Chaser720
The owners manual suggests putting the car into N when at a stop so the clutch doesnt get glazed over before engaging into 1st. And i down shift too but using the brakes is proabably a better idea.
??? Explain this one please. I thought with clutch in the only friction point was the clutch fingers, and throwout bearing. The throwout bearing is a spinning bearing meant to handle this from what I know. ???
What's changed now? What page is this? I'd like to check it out.
Old May 26, 2007 | 12:29 AM
  #48
roast's Avatar
roast
Shifting into neutral and releasing the clutch while at a stop is so you don't put unnecessary wear on the throwout bearing... the throwout bearing is not designed to handle the clutch being disengaged on a frequent basis for long periods of time.
BTW, it's on page 5-13, or refer to "shifting" in the index.
Old May 26, 2007 | 08:09 AM
  #49
OneI350's Avatar
OneI350
heel toe, neutral, revmatch,downshift, pop clutch,revmatch once more,back to neutral, then lastly, ghost ride da whip (all up hill) Best for pads and tran
Old May 26, 2007 | 12:46 PM
  #50
MeetJoeAsian's Avatar
MeetJoeAsian
go here and read up on "SHIFTING 101"
https://my350z.com/forum/2003-2009-nissan-350z/197329-the-top-100-common-questions-2.html
Old May 26, 2007 | 01:56 PM
  #51
Jabdo233's Avatar
Jabdo233
Originally Posted by NightRida
S
Old Jun 8, 2007 | 07:33 PM
  #52
Chaser720's Avatar
Chaser720
Lemoned Z
Yeah basicly what he said. I just read the manual.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
sherm
Apr 11, 2020 05:21 PM
seagrasser
Oct 11, 2015 03:27 PM
apex locator
Oct 6, 2015 05:58 PM
