Did I screw up my differential?
Old May 6, 2003 | 01:30 PM
Brad4rdHay's Avatar
Brad4rdHay
Unhappy Did I screw up my differential?
Well, a few weeks ago, I got my old wheels put back on while the iForged were sent back to be re-done. Well, it happens that one of the idiots put the front right wheel on the rear right position and vice versa. So what that means is that I was running different sized rubber left/right. They were configured like this for 1.5-2 weeks....took me a while to notice the problem, then more time to find time to take it down to the tire place to have them swapped. Now I've heard that running 200 miles on a spare is like doing 20,000 miles worth of wear on your diferentials (because of the diameter difference). Should I have new diferentials put in my car? SHould the tire place pay for them? What should I do?
Old May 6, 2003 | 01:35 PM
Ricky's Avatar
Ricky
I say put on your stock rims, go to a dealer, get a free check up, if anything is wrong, they will replace your diff. for free, or they should.
Old May 6, 2003 | 02:27 PM
teh215's Avatar
teh215
I agree with Ricky, get to the dealer ASAP. I would be willing to bet the differential is not shot but you may have shaved years off of its life...
Old May 6, 2003 | 02:30 PM
ares's Avatar
ares
Veteran
good time for the aftermarket LSD no?
Old May 6, 2003 | 03:13 PM
SunsetZ's Avatar
SunsetZ
I don't think the diameter difference is anywhere near as large as it would be using the temporary spare, so I don't think you did any harm. And yes I saw that episode of motor week on the speed channel about differentials and the spare tire.
Old May 6, 2003 | 04:38 PM
labshark7's Avatar
labshark7
I agree,
Slap the stock wheels on and say you are having trouble.
Or vice versa, take it in, aftermarket wheels should not affect your diff. Just make sure when you bring the car in, everything is set up correctly.
Eric
Old May 6, 2003 | 04:42 PM
TJZ's Avatar
TJZ
Hell yes! just use this as an excuse. They aftermarket lsds are better than stock anyway .
Old May 7, 2003 | 12:23 PM
Brad4rdHay's Avatar
Brad4rdHay
Yeah but I dont want o have to pay anyting....if its the tire places fault, then they should pay to have the stockers replaced with the stockers.
How easy it it to check differentials. Will the dealer charge me...im gonna head over there friday prolly so i huess ill get a deffinate answer then....
Old May 7, 2003 | 01:39 PM
Tom2's Avatar
Tom2
Don't worry, you did NO harm to your differential.
Think about it-- a differential is there to allow a "differential" in speed whenever you go around a turn.
That said, you must realize that the spider gears in a differential are turning different speeds unless you are going absolutely straight (equal speeds both rear tires). All other times, the differential is doing it's job and the spider gears are indeed spinning different speeds.
So don't worry, there's no harm done.
Old May 7, 2003 | 01:56 PM
boostd350Z's Avatar
boostd350Z
What is the difference in tire size?
If it's under a 3% change I would not worry one bit at all. I am sure that there is a decent amount of tolerance built into the system. People do absurd things to cars all the time, I think most auto makers are well aware of that and leave a margin of safety.
Old May 7, 2003 | 03:01 PM
D'oh's Avatar
D'oh
Yeah, I highly doubt you would have caused a problem. 225/40-18 VS 245/40-18 is about a 2.5% difference in diameter. I drive very twisty roads for 20 miles on the way to work, and if the diff was going to have problems from a 2.5% difference, then my car would be in big trouble. 15,000 miles so far and no problems with the diff (knocking on wood).
I wouldn't worry about it.
-D'oh!
Old May 7, 2003 | 05:24 PM
WayneTN's Avatar
WayneTN
I concur. I doubt very seriously if there was any real damage.
WayneTN
Juztin
Nov 22, 2015 07:03 AM
AbrasiveRaysive
Sep 13, 2015 09:52 PM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
Beater350z
Sep 9, 2015 03:36 PM
