Now the Z Whistles! This is not a laughing matter
Old Sep 19, 2007 | 07:31 AM
jolt3500's Avatar
jolt3500
Angry Now the Z Whistles! This is not a laughing matter
So I'll be driving and when I hit about 55-60 the my '05 starts to whistle from the drivers side. Its driving my crazy. Im thinking about taking it to the dealership but I dont know how much they really would do. But anyways I am almost for certain that it has to do with either the drivers side door panels or something in that area. I might just take it all apart and make sure everything if fitting perfectly again.??? Any ideas?
Old Sep 19, 2007 | 07:32 AM
Motormouth's Avatar
Motormouth
it's probably the weather striping around your window.
Old Sep 19, 2007 | 07:33 AM
jolt3500's Avatar
jolt3500
Hmm didnt think of that only because I always have my windows down and can still here it. I might still be them.
Old Sep 19, 2007 | 07:36 AM
Motormouth's Avatar
Motormouth
oh, then I have no idea. I remember people reporting this problem before and it was the weather striping, but the issue was when the window was closed.
and how can you hear whistling with your window down at that speed, lol! well, good luck.
Old Sep 19, 2007 | 07:40 AM
jolt3500's Avatar
jolt3500
I just turn the Bose up..
Old Sep 19, 2007 | 08:26 AM
cheshirecat79's Avatar
cheshirecat79
Could it possibly be the mirror assembly? I think it would have to be something close to you if you can hear it at speed.
Old Sep 19, 2007 | 08:29 AM
jolt3500's Avatar
jolt3500
Ill check it out Im just trying to get some suggestions for what to look for. It could be a lot of things.
Old Sep 19, 2007 | 08:31 AM
Nucleus's Avatar
Nucleus
Do you have an aftermarket air intake on your engine?
Old Sep 19, 2007 | 08:38 AM
ginobetterfly's Avatar
ginobetterfly
yeah i think it is... if you fold the mirror in, im betting you wont hear it anymore... that was my case anyways... but you obviously shouldnt be driving with folded mirrors so not much you can do besides (as previously mentioned) turn the radio up...
ZuperVinn's Avatar
ZuperVinn
do u have a cheap CD player? lol because i remember i had a CHEAP cd player in my 4th gen maxima lol. That **** whistle when i drive. THen when i turn it off. the whistle stops.
Old Sep 19, 2007 | 08:39 AM
azula's Avatar
azula
go that speed again and turn everything off.....try to pinpoint the exact location of the sound, we'll be able to help you a lil better. good luck.
Old Sep 19, 2007 | 08:43 AM
JCat's Avatar
JCat
Mine did too at 145mph. Cure = removed vertical door hinges.
Old Sep 19, 2007 | 08:50 AM
Skorch's Avatar
Skorch
Maybe you accidentally installed a blow-off valve...
Old Sep 19, 2007 | 09:29 AM
Motormouth's Avatar
Motormouth
if your mirror cover is loose off the base slightly that could give you a whistle. pop of the cover on the bottom and tighten the screws if you can and just make sure it's in the proper position, move it back then pop it back into place.
Old Sep 19, 2007 | 10:13 AM
ksandhu29's Avatar
ksandhu29
its the supercharger!
Old Sep 19, 2007 | 10:20 AM
asianflip06's Avatar
asianflip06
its prolly your driver side mirror....remove and check the seal....
Old Sep 19, 2007 | 10:54 AM
usmanasif's Avatar
usmanasif
Are there hot chicks in the car driving next to you when that happens?
Old Sep 19, 2007 | 01:08 PM
jolt3500's Avatar
jolt3500
Hey thanks for all the responses. It definately sounds like it is coming from the mirror or past. Nope no cai either.
Old Sep 19, 2007 | 01:26 PM
Britx's Avatar
Britx
LOL..Mine does that too but at EXACTLY 80mph. Just about eye level on the glass. simply press the rubber on the inside of the glass out a bit and this usually cures it.
Old Sep 19, 2007 | 03:29 PM
Ebony350's Avatar
Ebony350
http://video.google.com/videoplay?do...98347921827143 Gets interesting @ the 1m 7sec mark
