TCS: how does it affect the performance?
Old Feb 29, 2008 | 09:17 AM
maXmood's Avatar
maXmood
Under Boost!
Default TCS: how does it affect the performance?
if we have 2 stock A/T 350z, 1 with TCS on and the other with TCS off.
for 1/4miles, how is it going to affect the run?
note: i'm not encouraging any street racing. races belongs to the track.
thnx
Old Feb 29, 2008 | 09:25 AM
DavesZ#3's Avatar
DavesZ#3
It doesn't affect performance. It's there to prevent wheel slip. If your rear wheels start to spin, then TCS will cut power.
pchong154's Avatar
pchong154
You usually want to turn traction control off, if you want ***** out performance... If your gonna gun it in the first, second, or third gear your tires are probably going to break loose or "squeal."
If the comp. detects a slip in the wheels then it will cut the throttle, thus losing some time and acceleration.
Old Feb 29, 2008 | 09:42 AM
Brrcats's Avatar
Brrcats
yes, what those guys said, i've got the VDC, not the TCS, but when I run it I always have it off.
Old Feb 29, 2008 | 09:51 AM
For drag racing I turn TCS OFF. TCS will kill the car if it is ON at the starting line.
For autocross TCS is OFF. Coming out of a corner a little tire spin is OK. Again with TCS ON it will kill the motor.
Old Feb 29, 2008 | 10:08 AM
maXmood's Avatar
maXmood
Under Boost!
thnx.. i didn't mean to say that it will affect the performance in particular, but the outcome power for a 1/4mile..
at first, i thought that preventing wheel slip (TCS on) = to a better grip and a head start, but it wasn't. actually it was loosing some torque on 1st and second gears..
with wheel spinning from a dead start, we lose some time (probably a second or fraction of a second), without the wheel spinning (TCS on) we lose the jump as well.. but i don't know how can we compare the time lose in both situations.
i don't know if anyone tried this before, but would love to see some test results on both situation.
thnx
Old Feb 29, 2008 | 10:19 AM
I have inadvertently left TCS ON. The results are poor. Poor enough never to do it again.
Old Feb 29, 2008 | 10:40 AM
nothix's Avatar
nothix
leave tcs off and learn to launch the car.
tcs delays power for wayyy too long when it detects spin
Old Feb 29, 2008 | 11:16 AM
WhiteNoiz's Avatar
WhiteNoiz
done that before
Old Feb 29, 2008 | 11:45 AM
Hydro_Z's Avatar
Hydro_Z
Anyway to turn the TCS off permanently? I try doing burn outs and no luck. I've heard there's a switch behind the brake pedal, any truth to that?
Old Feb 29, 2008 | 12:02 PM
maXmood's Avatar
maXmood
Under Boost!
burnouts can be done once the TCS is off.. switching off the car and back on will turn on the TCS on again. i don't know about permanently switching it off.
Old Feb 29, 2008 | 12:05 PM
WhiteNoiz's Avatar
WhiteNoiz
I dont think there is a way to switch it permanently off. I remember a thread on here where a guy cut the wire for the tcs, and it was permanently off, but when he tried to reconnect it to sell the car, it wouldnt turn back on.
Old Feb 29, 2008 | 12:06 PM
SRTtoZ's Avatar
SRTtoZ
Try to do a burnout with TCS on...lol
I saw a new eclipse do it at the track when I had my SRT4, clutch go bye bye.
Old Feb 29, 2008 | 12:11 PM
My350P's Avatar
My350P
Re: TCS, I know KPtechnologies on this board sells a module that will allow you
to have it be off by default when you start the car.
However, if you are trying to do a burnout by gunning it and holding the brake, the problem is actually that the car cuts power if you are pressing the gas and brake pedal at the same time. To [temporarily] remedy this, you will have to take out your brake light fuse.
Old Feb 29, 2008 | 12:21 PM
my05350z's Avatar
my05350z
i may be wrong but i think you would rather the vlsd take car of the wheel spin. Also to execute a hasty u turn, the tcs must be off. just $.02
Old Feb 29, 2008 | 01:19 PM
Show us how that technique works for you here: https://my350z.com/forum/drag/233840-top-25-1-4-mile-times-for-tt-st-supercharger-nitrous-bolt-ons-stock.html.
Show us how that technique works for you here: https://my350z.com/forum/showthread.php?t=233840.
Old Feb 29, 2008 | 01:20 PM
Old Feb 29, 2008 | 02:02 PM
coachk's Avatar
coachk
Always turn the TC off for drag racing....I forgot to turn it off one time while doing a burnout in the water box and when I shifted to 2nd I could barely get the wheels to spin.
Old Mar 1, 2008 | 09:46 AM
Hydro_Z's Avatar
Hydro_Z
Cool to know, thanks guys. Hopefully I'll take some pics of a burnout to post soon, thanks!
EnjukuRacing
Sep 30, 2015 06:55 AM
Tochigi_236
Sep 27, 2015 03:40 PM
