The Z speed limiter
Old Apr 6, 2008 | 07:39 AM
  #81
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Originally Posted by carbon z
As to Ohio, 20 over gets you reckless op, big fine. Top speed, reckless op, big fine, loss of license, car impounded. HOW BIG ARE YOUR NADS? Try this in Ohio.
Double the speed limit in Texas gets you that. And since I was in a 80 mph zone, double that is 160. :P
Old Apr 6, 2008 | 07:43 AM
  #82
roast's Avatar
roast
Originally Posted by SOLO-350Z
Incorrect my friend. The Z at least the HR has more in it. Between 150-160 it actually was stilll pulling somewhat good and just stops at 160 instantly. The car can probably hit 170 stock at the most.
It isn't limited by gearing. But the DE was limited by engine output where the HR helps.
The DE is not limited by engine output.
All stock 350z's are ELECTRONICALLY LIMITED. There should be a bit of power left, and plenty of gearing. I've seen my speed limiter enough to know what I'm talking about...
Old Apr 6, 2008 | 08:02 AM
  #83
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
It does have a speed limiter, but it doesn't have the power of the HR to get that high without a speed limiter. I had a DE and it could hit 150s but it was pretty much a crawl after that.
So yes the DE is limited by engine output and RPM if you have no speed limiter. The DE has a lower RPM redline, and less power to the wheels.
Old Apr 6, 2008 | 08:24 AM
  #84
roast's Avatar
roast
The DE is electronically limited to 159. It will reach that speed and hold it up and down hills.
Edit - I think I can understand what you're trying to say now. Without the limiters, yes, the HR will reach a higher speed.
One would assume that's common sense.
Old Apr 6, 2008 | 11:35 AM
  #85
RBlover69's Avatar
RBlover69
the power to get that high.,i think the top end design of the revup would have no problem getting to a decent speed without a rev limiter.
Old Apr 6, 2008 | 12:47 PM
  #86
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
It may, but it just doesn't have the pull like the HR does.
Old Apr 6, 2008 | 02:11 PM
  #87
UMW350Z's Avatar
UMW350Z
Hit 159.9 on the dyno...held it for about 30 seconds to see if I could get that magical .1 more....nothing. I was damn nar redline...I don't think she will go more than about 10 mph more
Old Apr 6, 2008 | 06:00 PM
  #88
dfresh713's Avatar
dfresh713
Master
I hit about 110 on a turnpike today in 6th gear at about 4,000 rpms... i dont see it going more than 140mph without putting your car in the redline.
Old Apr 6, 2008 | 07:05 PM
  #89
HDPDZO6's Avatar
HDPDZO6
I would do some research then before making a post like you did. It shows ignorance in ragards to the capabilities of your car.
Old Apr 6, 2008 | 07:18 PM
  #90
da45king's Avatar
da45king
Default 1 mile an hour
I can't believe there is a fire fight over 1 mph. I had this arguement back in 2004. Noone believed me when I said I hit 158 in my G. Some magazne had the top speed limit at 142....others 155.
I think +/- 1-3 mph is within tolerance.
Old Apr 6, 2008 | 08:06 PM
  #91
TheStigZ33's Avatar
TheStigZ33
TheFastDieYoung
watch this video of me.
<object width="425" height="355"><param name="movie" value="http://www.youtube.com/v/2OOAw3coWGs&hl=en"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/2OOAw3coWGs&hl=en" type="application/x-shockwave-flash" wmode="transparent" width="425" height="355"></embed></object>
Old Apr 6, 2008 | 09:59 PM
  #92
dfresh713's Avatar
dfresh713
Master
I agree now... but what are your rpm's at when going that fast... your probably in 8k range
Old Apr 6, 2008 | 10:10 PM
  #93
TheStigZ33's Avatar
TheStigZ33
TheFastDieYoung
nope it was around 5800 or 6000, i can hit 145 in fifth.
Old Apr 7, 2008 | 04:10 AM
  #94
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Actually RPMS at 160 mph in 5th gear is around 7200 rpms. We still had 300 rpms till 7500.
The DE on the other hand hits redline at around 7200~ for the rev-up.
When I did my run I was in 5th gear at 160 mph.
Old Apr 7, 2008 | 12:31 PM
  #95
TheStigZ33's Avatar
TheStigZ33
TheFastDieYoung
yeah, your right! it was last year when i made my 160 run, i really couldnt remember i just made up something, but your correct.
Old Apr 7, 2008 | 01:27 PM
  #96
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
The reason why I remember, is because my shift light is set at 7200 and it kicks on right when I hit it, even in my videos. hehe.
Old Apr 7, 2008 | 01:54 PM
  #97
RBlover69's Avatar
RBlover69
really thats relative by all means a HRs reaching to 160 is no feat of enginerring and not that much of an improvement to get a award from a revup from what i seen lmao.
I find it funny ...anyone care to do a 0-160 times lmao. .....guarenteed not that serious lmao
Old Apr 7, 2008 | 04:18 PM
  #98
LHsilver350z's Avatar
LHsilver350z
Originally Posted by Robert_K
+++++++++++++++++++++++1
Old Apr 7, 2008 | 04:41 PM
  #99
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Actually, the DE only goes to around 6800 rpm max, if I remember right, maybe less. I had a 04 and a 05 G35. The 05 reved to 7200 rpm, the HR goes to 7500. The REV-UP is the only one that could reach that speed without shifting to 6th. And in 6th the car doesn't have the power to accelerate anyways.
Old Apr 9, 2008 | 02:38 AM
  #100
RBlover69's Avatar
RBlover69
in 6th you are still accelerating though. I also have driven all versions of the vq in the Z. the DE granted was the worst of the batch at top speeds with its curve literally dying uptop but to be honest with you between the revup up top and the HR at over 100 speeds the difference wasnt that pronounced as i hoped like lets say the g37 and the 3.7ltre engine which actually pulls really hard after 100= and you can feel the output of the engine come alive.
The 3.5 HR and the revup even though they both climb to the therotical top speed. Its not impressive to mention when compared to eachother or its competetion since most cars in this catagorey do reach the very same top speed.
But of course the HR has more power. But realize its power curve really makes its power lower int he rpm band aswell.
