350Z Weight Index
Old Apr 14, 2008 | 10:09 AM
projectsupra's Avatar
projectsupra
Default 350Z Weight Index
Has anyone compiled a weight index for the 350Z yet? I helped make one for the A70 Supra with a few other members, putting everything on the scale from body panels to engine parts. Since getting my Z's I've been saving weights of everything, both OEM and aftermarket. If anyone wants to help host/build a database for the weights post it up, or if there is already a good one I haven't found yet...
Old Apr 14, 2008 | 10:12 AM
Every now and them members will remove and weigh an OEM part. Unfortunately I usually forget.
Old Apr 14, 2008 | 01:54 PM
Fletch69z's Avatar
Fletch69z
I haven't ever seen one but that's an awesome idea.
Old Apr 14, 2008 | 01:57 PM
preludestuntin's Avatar
preludestuntin
That is a good idea. Sticky?
Old Apr 14, 2008 | 02:26 PM
350Zak's Avatar
350Zak
It'd definitely be nice to have all of it compiled in one list. Hope someone goes through with it
Old Apr 14, 2008 | 02:53 PM
BRONZEE's Avatar
BRONZEE
Club Moderator
Here's a few to start you off, bearing in mind the Cat might be slightly different, due to laws etc in NZ.
1. Stock Catatalytic converter x 2 = 14.75 Kg
2. Stock Y-Pipe = 7.25 Kg
3. Stock Mid pipe + Stock Muffler = 20.9 Kg
4. StockAxle assembly (right handside) = approx 8kgs
5. Aluminum rear subframe = approx 15kgs
6. Megan Racing stainless resonated front pipe x 2 = 7.25 Kg
7. Megan Racing stainless Y-Pipe = 4 Kg
8. Fujitsubo Legalis R Stainless Exhaust = 16 Kg
Old Apr 14, 2008 | 05:06 PM
pmohr's Avatar
pmohr
I might be able to start doing some of this, will likely have a place to host it, too. PM me in a day or so, and I'll let you know.
Old Apr 14, 2008 | 07:38 PM
hr350z33's Avatar
hr350z33
That is a great idea!
Old Apr 14, 2008 | 07:54 PM
roast's Avatar
roast
/me wishes this site would have started a wiki like 5 years ago.... then this idea would have already been done..... the amount of information that would be quickly accessible would be mind boggling... instead we have to bang our heads on the "search engine", if one would even call it that. Too bad that "other site" doesn't have enough members to make their wiki worth much. (although it is better than no wiki at all)...
Old Apr 14, 2008 | 08:00 PM
roast's Avatar
roast
so enough of my rant... i'm definitely interested in the weights of stock parts and the weights of aftermarket replacement parts.... my whole goal with the Z right now is shaving weight... so hell yes I'm interested... I have a whole pile of junk that I've already removed that I can weigh if needed (basically the entire rear interior of the car, from the seats back, speakers, stereo, stock battery....
Old Apr 14, 2008 | 09:08 PM
Spork's Avatar
Spork
Originally Posted by 05-Z
exterior
stock hatch: 77 lbs
hatch counterweight: 1.5 lbs
rear wiper and motor: 9 lbs
stock hood: 24 lbs
stock fenders: around 7.7 lbs each
headlight: 15 lbs each
interior
rear mat: 6 lbs
sound dampening "pads" in that space behind seats: about 5 lbs
shift ****: about 206 grams
leather heated seats: 50 lbs each
fabric seats: 37 lbs each
spare, jack, and tools: 40 lbs
headunit and speakers: about 7 lbs together
steel plate + bolts for subwoofer: about 5 lbs
suspension
stock sways: front 10.5 lbs and rear 4 lbs
stock spring and shock assembly: 10 lbs each
stock battery: 36 lbs
Standard Brakes
296x24mm Front Disc = 16.2 lbs
Single Piston Front Caliper = 12.2 lbs
292x15mm Rear Disc = 11.9 lbs
Single Piston Rear Caliper = 6.0 lbs
Track Model Brembos
324x30mm Front Disc = 20.0 lbs
4-Piston Front Caliper = 9.5 lbs
322x22mm Rear Disc = 17.6 lbs
2-Piston Rear Caliper = 4.3 lbs
fluids
full tank of gas: 6.5 lbs x 17 gallons = 110.5 lbs
full tank of washer fluid: 8 lbs
exhaust
plastic intake manifold: 4 lbs
stock headers: 15.4 lbs
rear muffler: 34 lbs
mid pipe: 12 lbs
y-pipe: 16 lbs
catalytic converters: 23 lbs each
wheels
(depending upon air pressure, almost any nissan tire + rim combo will be around 40-60 lbs each)
17" base rims F: 17x7.5 = 23.26 lbs and R: 17x8.0 = 24.140 lbs
18" track rims F: 18x8.0 = 18.1 lbs and R: 18x8.5 = 18.62 lbs
18" perf/touring rims F: 18x8.0 = 27 lbs and R: = 18x8.0 = 27 lbs
18" LMGT rims F: 18x8.5 = 18.3 lbs and R: 18x9.5 = 18.8 lbs
19" LMGT rims F: 19 x 8.5 = and R: 19x9.5 = around 22 lbs
all 20 lug nuts: 2.6 lbs
drivetrain
stock clutch weight: 22.19 lbs
stock flywheel weight: 23 lbs
crank pulley: 6 lbs
From Top 100 Questions thread.
Old Apr 14, 2008 | 09:13 PM
zonic03's Avatar
zonic03
Good info peeps!!
Old Apr 15, 2008 | 02:37 AM
projectsupra
Must have missed that one. Maybe my scale is a bit off, I got 22lbs for my OEM 07 hood and 5lbs for the front fenders. There is no way the sound dampening pad/s under the glove box are 5 lbs, a pound or two would be more like it. I'll just post a few of my findings that haven't been listed here then.
OEM hatch complete (no weight) - 76 lbs
OEM hatch bare - 50 lbs
OEM hatch glass - 14 lbs
Seibon carbon fiber hatch bare - 20 lbs
OEM fenders - 5 lbs
fiberglass fenders - 3 lbs
OEM roadster trunk complete - 25 lbs
OEM 07 aluminum hood - 22 lbs
Seibon carbon fiber hood - 20 lbs
Old Apr 15, 2008 | 03:43 AM
Z04's Avatar
Z04
IMO a waste of time unless the car is a full time racing car. weight does not matter on the streets
Old Apr 15, 2008 | 05:30 AM
roast's Avatar
roast
If it's such a waste of time, why are you wasting your time in this thread?
Old Apr 15, 2008 | 05:32 AM
Jim@Showstoppers's Avatar
Jim@Showstoppers
OEM fenders - 5 lbs
Mastergrade hatch bare - 12lbs
Mastergarde Venom hood- 11lbs
Thats all I have right now, I'll try to get some more.
Old Apr 15, 2008 | 05:34 AM
roast's Avatar
roast
It's exactly that kind of junk that makes threads a cluster ****. No fault of yours. Half of those weights are wrong...and then nobody can edit it and make it right or have discussions on certain items in question without having one long convoluted mess.
blegh.
issyz
Jul 2, 2017 03:04 PM
wanderingstuden
Jan 28, 2016 07:03 PM
Justin100
Nov 29, 2015 03:58 PM
tm9293
North East Marketplace
13
Oct 17, 2015 09:14 PM
codek
Sep 28, 2015 03:03 AM
