Extend the range of the OEM Keyless Entry
Old Jun 30, 2008 | 05:42 PM
cantfindaname's Avatar
cantfindaname
Default Extend the range of the OEM Keyless Entry
Has anyone successfully extended the range of their keyless entry?
If so, could you please help a brotha out?
Old Jun 30, 2008 | 05:48 PM
xDIEGOx's Avatar
xDIEGOx
No
Old Jun 30, 2008 | 05:55 PM
stein's Avatar
stein
Try this
http://www.youtube.com/watch?v=IRQWV0Zj8Fg
Old Jun 30, 2008 | 05:56 PM
zand02max's Avatar
zand02max
Originally Posted by xDIEGOx
No
Old Jun 30, 2008 | 06:03 PM
cantfindaname
Originally Posted by stein
Hahaha.... I've was looking for a more permanent approach.
I remember from several aftermarket alarm installations I have done in the past that they all had a wire that was the remote antenna. You could simply lengthen the wire, and run it around the engine bay for added range.
I'm not looking for anything unreasonable here - just would like to get it working past 10-15 feet.
I should have also noted in my initial post that I've already changed the batteries in the remote. Did nothing.
Old Jun 30, 2008 | 06:17 PM
stein's Avatar
stein
You'll need to either solder on an extension to the fob or the cars antenna something like
http://www.instructables.com/id/Exte...eyless-entry./
I've not tried it so your on your own here.
Old Jun 30, 2008 | 06:20 PM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
That only works if you've got a metal plate in your head!
Old Jun 30, 2008 | 06:41 PM
jwillard0201's Avatar
jwillard0201
Whats more permanent than holding it to your head?
I know mine has a pretty far reach on it. Maybe you should order another fob and see if it changes the distance.
Old Jun 30, 2008 | 06:42 PM
cantfindaname
That may actually work. Thanks!
Old Jun 30, 2008 | 06:50 PM
sk26dett's Avatar
sk26dett
I hold it above my head, extends the range by like 20 feet, at waist level mine doesn't work from over 10-15ft away. Above my head i can get to work almost 30-40 feet away, unobstructed that is.
Old Jun 30, 2008 | 06:54 PM
jwillard0201
Actually mine works from inside the house and from the backyard and my car isnt even in sight and its well over 40 feet away in both instances.
Old Jun 30, 2008 | 06:55 PM
Pun1sh3RZ's Avatar
Pun1sh3RZ
upgrade to viper alarm
Old Jun 30, 2008 | 07:08 PM
hotshot350's Avatar
hotshot350
try putting the remote to your chin and push the button. It works for me when im out of range. it's something like a human antenna lol. This works for most cars.
Chad68's Avatar
Chad68
I increased mine by about 50%. I switched the Z's dsr-pl chip with the chip from a 2003 Audi, which uses a dsr-ps-tr3 series chip.
The Audi chips fits perfect in the Z's fob.
Just reprogram the Z'z reciever and yer done.
Old Jun 30, 2008 | 09:02 PM
gregom's Avatar
gregom
...just would like to get it working past 10-15 feet.
That's it? Change the battery man... mine works pretty far away, the other night I wasn't sure if I locked my car walking into a hospital and was probably 80 feet away, turned around and pressed lock and it flashed.
I don't think there is a whole lot that can be done to increase the transmit power unless you use some other type of device and adapt it for use as a remote for the car.
Old Jul 1, 2008 | 05:10 AM
chickenputo's Avatar
chickenputo
Hold the transmitter to your chin.
Old Jul 1, 2008 | 07:23 AM
The Captain's Avatar
The Captain
+1 This actually works. I was skeptical my self, but one day I was walking towards my car and from I just pushed the top of the key fob up to my chin and pressed the unlock. The lights flashed and the doors unlocked from way further than the "shooting from the waist" action could reach.
Old Jul 1, 2008 | 09:59 PM
gr8scott_o's Avatar
gr8scott_o
Yep, absolutely works with any car I have ever had. No metal plate in my head, either!
Old Jul 2, 2008 | 04:32 AM
SirSpeedyZ's Avatar
SirSpeedyZ
i usually just hold it next to my head, works like a charm
Old Jul 2, 2008 | 11:26 AM
sir captian's Avatar
sir captian
Mine works from about 30-40 yards no bs
