Can u burnout with the LSD?
Old Jul 25, 2003 | 07:42 AM
Zulu's Avatar
Zulu
Default Can u burnout with the LSD?
I dunno if this can be done, but I read on another thread that you can power brake if you remove the brake fuse. Does the LS diff get in the way? Any directions and I'll try it right away ( well, after I get out of work, that is1 ).
Old Jul 25, 2003 | 09:28 AM
ares's Avatar
ares
Veteran
LSD is purely mechanical(or viscous in our case I guess) no electrical components I dont think.
its basicly the only way to do a burnout... it forces both tires to spin, without it youd do the dreaded one wheel burn out(you know the civic everyone laughs at at the drag strip?)
Old Jul 25, 2003 | 10:35 AM
N74DV's Avatar
N74DV
see sig...... it can be done
Old Jul 25, 2003 | 11:02 AM
zh.guitar's Avatar
zh.guitar
Leave your mark!
I burned out on LSD once too.
Old Jul 25, 2003 | 11:59 AM
jckolnturn's Avatar
jckolnturn
LMAO
Old Jul 25, 2003 | 12:19 PM
Zulu's Avatar
Zulu
Okay, so it can be done, but the question remains - do I have to remove/unplug anything?
Old Jul 25, 2003 | 01:05 PM
syf0n's Avatar
syf0n
Turn off your TCS or VDC....that's it.
Old Jul 25, 2003 | 04:14 PM
ares's Avatar
ares
Veteran
yeah should do it, Ive heard that brake thing, but I guess it goes both ways, dont HAVE to do it. supposedly because its drive by wire, if the brake is down, the computer limits the amount of HP itll put out. however real life testing up there says otherwise.
Paul.
Oct 16, 2015 07:34 PM
seagrasser
Oct 11, 2015 03:27 PM
RiujinZero
Sep 25, 2015 01:19 PM
3vilbunny
Sep 13, 2015 12:31 PM
