Skipping Gears when shifting?
Old Jul 20, 2008 | 01:00 PM
Superfly84zx's Avatar
Superfly84zx
Default Skipping Gears when shifting?
Does changing gears from 2nd to 4th then to 6th hurt the transmission? I read in the manual that you can be in 6th gear around 40miles an hour and it seems pretty easy just to skip 3rd and 5th when driving easy...But does this cause any issues or harm? I've tried it for a week or so and its not seeming to be difficult to shift or anything...
Anyone know if this is a good idea or not?? Thanks
Old Jul 20, 2008 | 01:05 PM
Snowhiteboiler's Avatar
Snowhiteboiler
I doubt that it hurts anything... I remeber reading that corvette's MTs automatically skip from 1st to 4th if the rpms/speed weren't high enough (cruising vs. hammering it)
Old Jul 20, 2008 | 01:07 PM
whitecel's Avatar
whitecel
I don't think it would.
Old Jul 20, 2008 | 01:12 PM
Datapimp's Avatar
Datapimp
I do it just about everyday and for the past year or so. Not a single problem so far.
gregom's Avatar
gregom
It wears your synchros down a little bit but as long as you aren't grinding gears or slipping the clutch you should be fine.
Old Jul 20, 2008 | 01:44 PM
Dozzi94's Avatar
Dozzi94
I don't want to sound as if I'm contradicting you, but how does it wear synchros down any more than just regularly shifting into gear?
Old Jul 20, 2008 | 02:04 PM
woogie12's Avatar
woogie12
I would assume since there is a bigger gap in the revs matching.
Old Jul 20, 2008 | 02:06 PM
token5gtd's Avatar
token5gtd
double clutch when you skip gears and there should be 0 extra wear
Old Jul 20, 2008 | 02:23 PM
Chaser720's Avatar
Chaser720
Lemoned Z
My dealership said that it ruined my transmission. Then i told them they were all dumbasses and got someone who wasnt stupid and got a new tranny free.
So no its fine.
Old Jul 20, 2008 | 02:28 PM
Spork's Avatar
Spork
It doesn't affect anything, assuming you rev-match at least a little
Old Jul 20, 2008 | 02:34 PM
KingBaby's Avatar
KingBaby
Hardest Setting
+1 thats what I heard also
Old Jul 20, 2008 | 02:46 PM
Sure why not.
Old Jul 20, 2008 | 02:58 PM
MUZZY's Avatar
MUZZY
the vett those that to pass the national standard for fuel consumption during acceleration.
the GTO and other big motor cars that eat gas do this also
Old Jul 20, 2008 | 03:27 PM
Escobar's Avatar
Escobar
harmless...if done correctly. Make sure you rev match and don't bog it down.
Old Jul 20, 2008 | 03:34 PM
NISMO_558's Avatar
NISMO_558
It's suppose to bad for the syncros, by skipping gears they don't have time to catch up to the engines rpm
Old Jul 20, 2008 | 04:40 PM
racerfreakxxx's Avatar
racerfreakxxx
old trannies(like old school old) you couldn't do that in but the new ones are made to skip gears... that is why you can go from 2nd to 5th if you want
keptman's Avatar
keptman
Old Jul 20, 2008 | 05:09 PM
JCSVT's Avatar
JCSVT
You should be fine.
Old Jul 20, 2008 | 05:20 PM
banshee's Avatar
banshee
I think this is part of the reason to have a manual... so you can do things like this when you need to.
Old Jul 20, 2008 | 05:25 PM
Get_Zwole's Avatar
Get_Zwole
i do it everyday. I usually dont use 5th gear when getting on the highway i just go 4th to 6th. Shouldnt be a problem.
