PSI Alarm
Old Aug 8, 2003 | 07:33 AM
KMarcin's Avatar
KMarcin
Default PSI Alarm
This morning my PSI indicator started to flash (and the alarm went ff, which freaked me out because it was the first time I've heard it...). I adjusted my tire pressure but the indicator light is still on... I've checked with my dealer to no avail...
Any suggestions.?
Old Aug 8, 2003 | 07:39 AM
Beaker02's Avatar
Beaker02
Did you indeed find a tire low?
How low?
Did you correct it?
Sometimes sensors can take a few minutes to reset.
If all was well I would suspect a prob with the computer.
Old Aug 8, 2003 | 07:41 AM
Beaker02's Avatar
Beaker02
Sorry. I see that you did correct it. (still asleep this morning.) How low was the tire?
Old Aug 8, 2003 | 07:46 AM
KMarcin's Avatar
KMarcin
The air pressure was not low... It seemed that the gauge was not registering the pressure in the left front tire. I did add - then release some air in hopes it would reset the indicator. No luck...
Also, any suggestions on "cold" air pressure for the Z? Does anyone make adjustments for long-distance vs. city driving?
Old Aug 8, 2003 | 07:53 AM
daytona350z's Avatar
daytona350z
just fill the tire with the normal setting, 35psi all around, drive for a while +/- 5mins and it should go away.
at least thats what happened to me
Old Aug 8, 2003 | 07:57 AM
Beaker02's Avatar
Beaker02
Have you taken it out for a drive to try to make the alarm stop?
Old Aug 8, 2003 | 08:10 AM
KMarcin's Avatar
KMarcin
Yes, I have taken it out twice today... no luck as yet.
Old Aug 8, 2003 | 03:05 PM
supra crazy's Avatar
supra crazy
whats the psi because when i went on vacation for a month and came back my tire pressure was to low then i went a filled it up a bit and it was still on because it was to high.
Old Aug 8, 2003 | 10:00 PM
Beaker02's Avatar
Beaker02
Well at least it will be doing it when you take it to the dealer!
apex locator
Jul 23, 2021 02:27 AM
kyin
Oct 15, 2015 05:54 AM
seagrasser
Oct 11, 2015 03:27 PM
kyin
Sep 29, 2015 06:57 AM
