High/Freeway downshift question...
Old Dec 18, 2008 | 07:57 AM
  #41
konaforever's Avatar
konaforever
Originally Posted by 3fittyBiH
1st FTW
You try first!
Old Dec 18, 2008 | 09:41 AM
  #42
t0mills's Avatar
t0mills
Maybe it's just me, but my 3rd gear only takes me to 80mph in my '03 Z.
Stock rev limiter.
-Tim
Old Dec 18, 2008 | 09:47 AM
  #43
konaforever
Stock rev limiter.
-Tim
Do you have an auto or manual? They have a different final gear. Anyway, according to this, you either max out at 94 or 89 mph, depending on your transmission.
On my HR, 3rd goes to over a 100 mph.
STOCK 3.357 Gear-- ECU REFLASH 3.357 ---HR Engine
6600 Rpm Redline --------7200 Rpm Redline----------7500 Rpm Redline
First------40mph ------First-----44mph-----------First-----46mph
Second ----66mph ------Second----71mph-----------Second----74mph
Third------94mph-------Third----102mph-----------Third----107mph
Forth-----120mph-------Forth----131mph-----------Forth----136mph
Fith------152mph-------Fith-----166mph-----------Fith-----173mph
Sixth-----192mph-------Sixth----209mph-----------Sixth----218mph
STOCK 3.538 Gear-- ECU REFLASH 3.538 ---HR Engine
6600 Rpm Redline -------7200 Rpm Redline-----------7500 Rpm Redline
First -----38mph ------First-----42mph-----------First-----43mph
Second ----62mph-------Second----68mph-----------Second----71mph
Third -----89mph-------Third ----97mph-----------Third----101mph
Forth ----114mph-------Forth----124mph-----------Forth----129mph
Fith -----144mph-------Fith-----158mph-----------Fith-----164mph
Sixth ----182mph-------Sixth----199mph-----------Sixth----207mph
Old Dec 18, 2008 | 10:02 AM
  #44
t0mills's Avatar
t0mills
It's a 6mt.
Hmmm, that chart doesn't look right for my car. I'm at the very top of 4th when I go through the traps at 101-102mph.
2nd gear also doesn't quite net me 60mph. More like 57-58mph.
The rear end is stock as far as I know...
-Tim
Old Dec 18, 2008 | 11:23 AM
  #45
Parker01's Avatar
Parker01
Holy cow this is turning into a science.
Simply put, whether you are in 3rd upshifting or downshifting at a set speed your RPM's are going to be the same. So drive you car through the gears and pay attention to your RPM relative to your speed. Drive your car enough and it will be second nature which gear you select.
The biggest thing is, don't beat on your car senslessly. Drive it hard but don't do ricer downshifts while cruising down the highway. What I mean by this is when you downshift to take off, downshift and then let the clutch our at a moderate pace, allow the engine RPM's to speed up and then, PUNCH IT! Your transmission and engine will thank you by not grenading itself.
Old Dec 18, 2008 | 11:29 AM
  #46
0jiggy0's Avatar
0jiggy0
It's a 6mt.
-Tim
Are yo uon stock rims and tires?
Old Dec 18, 2008 | 12:00 PM
  #47
t0mills's Avatar
t0mills
Stock 18" touring wheels, with stock sized NT555s...
My speedometer has been verified accurate by my GPS.
One thing it might be, is that I can't go ALL the way to 6600. The rev limiter seems to hit around 6400.
-Tim
Old Dec 18, 2008 | 03:31 PM
  #48
matthew122's Avatar
matthew122
Originally Posted by TreeFiddyZee
If you drop from 6th at 70+ to 3rd, you're gonna get a rude awakening. If you're in to replacing internals, knock yourself out.
2nd gear goes to nearly 70mph on the HR, I always drop to third at highway speeds. If i'm going 50mph i'll even drop to second... talk about pinning you back in the seat
Old Dec 18, 2008 | 07:44 PM
  #49
usmanasif's Avatar
usmanasif
I'd throw that sucker in reverse. A lot of torque.
Old Dec 21, 2008 | 01:16 AM
  #50
zpak's Avatar
zpak
Originally Posted by Kirk Lazarus
Drop it into 1st for maximum horsepowers.
(sorry, late to thread)
Just read that, and I haven't laughed out loud in a while, but that was funny.
OP, like everyone said, if you're doing a 6-->3, rev-match. All things being equal, 6-->4 is probably better for clutch longevity.
Old Dec 25, 2008 | 09:08 AM
  #51
350z Guy's Avatar
350z Guy
play around and see what gear is the best id say
downshift one gear at a time, but make sure you are rev matching while downshifting
dont want to have a busted transmission
Paul.
Oct 16, 2015 07:34 PM
FromGtoZ
Sep 20, 2015 03:41 PM
