My Parking Lights are Out!
Old Sep 3, 2003 | 06:17 AM
ZZZZME's Avatar
ZZZZME
Lightbulb My Parking Lights are Out!
Hey everyone,
So I installed a new radio and the other night I realized that
the parking lights are out! Front and back....
Everything else works fine and I have checked ALL fuses!
Any ideas?
Thanks
Mike
Old Sep 3, 2003 | 09:25 AM
mike952's Avatar
mike952
Yes. I had the same issue on my first Z some time ago. During the install, you may have grounded something by accident. Go to the fuse box behind the battery..you have to disassemble the top cowel (it's in two pieces..so just take out the half where the battery is. There is a forum somewhere here where I took pictures of all this.
Also, make sure your radio illuminates at night after you plug in the right fuse.
Old Sep 3, 2003 | 09:52 AM
ZZZZME's Avatar
ZZZZME
Thanks for the heads up Mike,
Actually I replaced the factory radio and got no
illumination.
Do you by any chance know exactly what thread
that was with the pics?
I did a quick search but nothing.
Thanks
Mike
Old Sep 4, 2003 | 09:07 AM
mike952's Avatar
mike952
Try putting the stock radio back in and see if you have illumination when you turn on your lights. If you don't, then you fried the computer guage cluster (the one above the steering wheel) -- it took a while for them to discover this in my car....but the fix was getting a new guage cluster.
It turns out that one of the wires is ground when the lights are off and non-grounded when the lights are on (really wierd)...but that confused my installer...as he tested and assumed it was ground...while installing -- best thing, use or make your own ground.
First I suggest replacing the fuse behind the battery to get your brake lights back on (there are some pictures on the second post). Then, if you don't have illuimation...in the radio..try the stock radio. If the stock radio is not illuminated, then you have the same issue I had.
(I just noticed the pictures were external links, but I can't find them now)...
Original Thread:
https://my350z.com/forum/showthread....parking+lights
Parking Light Thread:
https://my350z.com/forum/showthread....threadid=14145
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
