shift indicator?
Old Aug 25, 2002 | 07:27 AM
goofyZ's Avatar
goofyZ
Default shift indicator?
being a truely narotic individual I set my shift indicator for 3500 not wanting to exceede 4000 rpm. (an almost impossible task i might add). the light is preety accurate on shifts from 1-2 less so from 2-3 and after that it lights up any where from 2900 t0 3500 usally in to low 3000 area. Is this suppose to happen for a reason ( I don't know mabey its anticipating the rate of acceleration or wants me to shift earlier on highr gears {I know it dosen't make sence but..}
Old Aug 25, 2002 | 07:30 AM
jeffw's Avatar
jeffw
I don't have the car yet, but I think it's supposed to start flashing like 400 rpm or so before the rpm that you set in the computer. Once you reach the set rpm, the light goes solid. You might want to program for 4000 rpm even.
The exact way it works should be in your car manual. Or you can search for the pdf 350z manual online (posted here somewhere).
Congrats on getting your car!!
Jeff
Old Aug 25, 2002 | 07:34 AM
goofyZ's Avatar
goofyZ
I don't think it's doing it properly. it does flash early but not at a consistant rpm.
Old Aug 25, 2002 | 07:55 AM
LowFuel's Avatar
LowFuel
Just getting but I bet it varies where it starts blinking based on how fast the rpm's are climbing? So you have enough time to react.
Old Aug 25, 2002 | 11:16 AM
z350z's Avatar
z350z
Charter Member #13
The manual says it starts flashing 500 RPM before the set RPM, then goes steadily on at the set RPM. So you don't need to set it for 3500, set it for 4000 and you will get the warning ahead of time. I think it may not correspond exactly with the needle because the needle take some time to sweep up the dial and may lag behind the actual RPM.
Old Aug 25, 2002 | 04:40 PM
esk01998's Avatar
esk01998
Does the shift light come on all models?
Old Aug 25, 2002 | 05:33 PM
rai's Avatar
rai
All models with manual transmissions. Not on slush boxes
MAsSIVrOOM
Oct 20, 2023 10:50 AM
sherm
Apr 11, 2020 05:21 PM
Depravity
Oct 1, 2015 04:49 PM
hardwood66
Sep 8, 2015 04:31 AM
