Splash guards...
Does anyone know if the spalsh guards are removable, and where they attach? Are they mounted from inside the wheel well or are holes drilled in the exterior of the body?
From the pictures it looks like the screwes go in from the outside and it should be an easy removal since they a a port installed option, you just have to put the screw back in I would assume.
Where are the screws? If you remove them, are there visible holes in the side of the body? or do they attach from inside the wheel well? Does anybody who has a car with splashguards have the answer?
