Is this a problem?
Old Aug 23, 2009 | 12:28 PM
rockmonkee10's Avatar
rockmonkee10
Default Is this a problem?
I have an 04 enthusiast and whenever I shift, down or up the rpms go up to at least 3000 then back down to whatever it should be. Is this something I need to worry about?
Old Aug 23, 2009 | 12:32 PM
KingBaby's Avatar
KingBaby
Hardest Setting
so to clarify....if coasting...you shift, and before getting back on the gas...the car revs up to 3k...
Old Aug 23, 2009 | 01:10 PM
rockmonkee10
No say when I'm going from 4th to 5th and my rpms are already low they will go up once I let off the clutch and gas it then they will go back way down. And I think I'm losing torque bc of this problem.
Old Aug 23, 2009 | 01:23 PM
blktrack350's Avatar
blktrack350
u are giving it gas before the clutch is all the way out it seems like.
Old Aug 23, 2009 | 01:24 PM
Emski's Avatar
Emski
Sounds like your clutch is slipping.
Old Aug 23, 2009 | 01:32 PM
rockmonkee10
Would any of that have to do with
me having to get up to 2.5k rpms in first gear to get it moving?
Old Aug 23, 2009 | 01:37 PM
CaliTouring's Avatar
CaliTouring
sounds like a really worn out clutch
Old Aug 23, 2009 | 01:46 PM
rockmonkee10
If it's the clutch how much would it cost to fix it?
Old Aug 23, 2009 | 01:47 PM
You shift at, say, 3,000 RPM, and the RPM goes UP to 6,000 RPM?
Old Aug 23, 2009 | 01:49 PM
larue582's Avatar
larue582
^+1^
Your clutch is slippin dude. I had the same problem these guys know wut there talking bout. I just purchased a Clutch 2 settle this issue. My problem was the exact same 5th went then 3rd and 4th so now I just parked it and replaced it.
Old Aug 23, 2009 | 01:50 PM
larue582's Avatar
larue582
Depends on Clutch and if you have to most likely replace your Flywheel.
Old Aug 23, 2009 | 02:14 PM
How to check slipping clutch:
6th gear at 60 MPH
Step on gas
Does engine RPM jump but car will not accelerating? If yes the clutch is slipping.
Old Aug 23, 2009 | 02:38 PM
rockmonkee10
ya I just figured out how to test it and it is slipping. This is one of those fml momments.
Old Aug 23, 2009 | 02:39 PM
rockmonkee10
6th gear at 60 MPH
Step on gas
Yeah that's how I tested it.
Old Aug 23, 2009 | 02:47 PM
The clutch disc is not holding the flywheel. The disc may be replaceable. But the majority of members go with a new clutch and flywheel at the same time.
Old Aug 25, 2009 | 02:46 AM
sno's Avatar
sno
Might as well go aftermarket because the dealership will charge you $1,400 for an OEM flywheel.
I bought the JWT stage 2 clutch and lightened flywheel from a vendor on this site for $700 I think. I would recommend that route.
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
