Problem while filling up with gas.
Old May 11, 2012 | 07:31 PM
jonnyrockets07's Avatar
jonnyrockets07
Question Problem while filling up with gas.
So you know while your getting gas, how once your tank is full, it forces the handle down so your tank doesn't overflow, and if you try to pull it again it will force the handle down right away? Well recently my car has been doing this more and more.. at first it started doing it while my tank was 1/2 full.. and I knew it wasn't full because I only reached $40 its saying its full.. When it happens, I try putting the nozzle in on different angles etc but once it 'thinks' its full there's no tricking it. so I just have to hang it up and say screw it half is good enough for now.
So usually it will fill right to full ~ ($75) in one shot, but recently its been doing it more and more and today I only reached 1/4 tank and it 'thought' it was full and forced the handle down.. so now I'm getting worried that it's going to start doing it every time or something.. I just want to fill my tank and be on my way
I realize this is a very odd question and I doubt anyone has ever had this problem.. but if you have or just know of a solution, please feel free to enlighten me
Thanks!
Old May 11, 2012 | 08:09 PM
mr. sparco's Avatar
mr. sparco
I've had this problem since I bought my car back in 05. It only happens at certain gas stations or with certain nozzles. Possibly with the way it seals up with the car causing the false stop. It gets annoying but rarely happens.
Old May 11, 2012 | 08:21 PM
SLId3W4YS 89's Avatar
SLId3W4YS 89
it happens to me all the time as well, it just depends on what gas stations i go to, I have figured out which ones to avoid now, but it has always happened to me.
Old May 11, 2012 | 08:25 PM
AngelsVQ's Avatar
AngelsVQ
yup happens to me all the time as well. then i "tinkle" the gas in for about 5$ then it locks and fills up again. no idea why...
Old May 11, 2012 | 08:41 PM
thespottedcow's Avatar
thespottedcow
ugh this happened to me tonight, i only ended up filling up like half way, i was so over holding it like 1/4 of the way so it wouldnt stop, but it took forever to fill.
Old May 11, 2012 | 09:03 PM
hndumafia's Avatar
hndumafia
you guys that are having the problem, have you had the tsb completed for the fuel hose? i am curious because i was having this problem recently, and never had the tsb done. curious if i should take the car in for that, or if i even can still have it done.
Old May 11, 2012 | 09:10 PM
mr. sparco's Avatar
mr. sparco
Didn't even know there was a TSB out for the car, thanks.
Old May 11, 2012 | 09:15 PM
Besides the other 20 gas fill problems threads this is the first I have heard of it.
Old May 11, 2012 | 11:01 PM
jdm5596's Avatar
jdm5596
dont think it has something to do with the vapor building up pressure and forcing the gas handle to shutoff? the fill tube is probably angled really sharp to prevent thieves, and the gas handle and pump flows faster these days and that might cause the funnel to fill up and shut the handle off...try pulling it out a lil and put it on a slower speed when filling
Old May 12, 2012 | 03:14 AM
JCITY's Avatar
JCITY
I agree with other posters.
Different gas stations,different results.
I gas up at the ones that have no problems.
It is what it is,don't stress on something that
you really can't fix.
Old May 12, 2012 | 04:10 AM
WeightLimit's Avatar
WeightLimit
This is what I do, works fine.
Old May 12, 2012 | 06:19 AM
Blu Hvn's Avatar
Blu Hvn
I had the same problem with mine and the dealer told me it was the gas station pumps causing the problem. I told him about all the reports here about the same issue and he claimed he knew nothing about it.
One day while attempting to fill up it happened at my BP station. I eventually drove to 2 other stations (all different brands) and the problem persisted so I knew it wasn't the station pumps.
Later there was a TSB which they performed and it solved the problem.
Old May 12, 2012 | 11:15 AM
Cody750's Avatar
Cody750
if i would have never actually read this forum i wouldnt have known, i first seen it about six months ago when i joined the forum and there were 500+ replies to this "problem"
Old May 12, 2012 | 05:37 PM
mr2blackna's Avatar
mr2blackna
I have an 07Z and it does this too. It really depends on the gas station I try to fill it up at. Certain Parkers stations works find and certain one doesn't fill all the way. I don't really care since I never go on road trip with my Z anyways. 5 gallons of gas will get me around town just fine.
Old May 12, 2012 | 05:58 PM
mrbdub's Avatar
mrbdub
What is a"TSB".
Old May 12, 2012 | 06:03 PM
SparkleCityHop's Avatar
SparkleCityHop
Living in 350Z
You have to be gentle with her… just stick the head in a little bit, don't cram the whole thing in there. That's what works for me.
Old May 12, 2012 | 07:08 PM
engiNERD350Z's Avatar
engiNERD350Z
Turn the nozzle 180 degrees. Yes, upside down. Trust me. I've been on here a long time, old issue, old solution. Good luck.
Old May 13, 2012 | 12:40 PM
Cody750's Avatar
Cody750
Originally Posted by mrbdub
What is a"TSB".
technical service bulletin; not exactly a recall just something for mechanics to look directly at before trouble shooting everything else
Old May 18, 2012 | 09:53 AM
Arnie de Gracia's Avatar
Arnie de Gracia
i experience this problem every once in a while....thought its really weird. i don't think anyone has explained this issue at best but its really no big deal! its just annoying sometimes when you think moving to the next pump would fix it!
Old May 18, 2012 | 04:10 PM
BAUSauto's Avatar
BAUSauto
Vendor - Former Vendor
works everytime...
