glad to be back
Old Jul 2, 2012 | 12:04 PM
Mcutali's Avatar
Mcutali
Default glad to be back
glad to be back on here! my350z! ive been building a boosted miata and i have had to suffer on miataturbo.net ridiculous people on there.
little about my z
Bought this car at Elite Motors in Tampa Fl
2004 350z touring 81k miles
Suspension/Brake/Wheel: Tein basic Coilovers were replaced with Bc Racing Coilovers,Spc front control arms,Spc Rear Camber Kit,Spc toe kit,Stillen Sway Bars(glow n dark powdercoated),custom built adapter spacers,borbet bmw style 95 19x9.5 19x10+24
im sitting at -1 with my spacer set up.
Agency Power brake lines + clutch line, drilled/slotted rotors,and Ams Pads
Engine: nismo cai converted to short ram k&n filter with jwt heat shield,z1 headers,z1 test pipes,xo2 catback,ported polished upper+lower plenum front runners chopped down,motordyne 5/16 plenum spacer,lower collector thermal gasket,ams crank pulley,Jwt S2 Clutch Kit Flywheel,turboxs utec+tuned bunch of silicone hoses that do nothing for power gains lol z1 and samco mix matched.
Car was completely repainted in 2011 at Mcgregor Autobody by long time friend James Didio. Car was shaved of f+r emblems, rear wiper. Strafe V2 front end. 2006 oem taillights, Agency power shorty antenna, oem trunk spoiler, fenders rolled,Color Matched handles. and SMD led Everything
Audio: Infinity Kappa 5channel, Infinity Kappa 6.5 Component Set with crossovers, rear 6.5 two ways Infinity kappa, Knukonceptz wiring + distribution blocks, Pioneer avh3100 6.5in in Dash DVD, Dynamat Extreme entire trunk+cubbies. Zenclosure stealth box, custom amp rack in oem sub location.
Just acquired a 04 g35 de engine 80k miles blown headgasket, I picked it up for next to nothing. Plans are to crack it open build it for boost, I'd be Happy with 500wheel and the more torque the better.. Im currently pulling another de apart for a friend thats building one for crazy power.
Old Jul 10, 2012 | 04:52 AM
BoomerZ33's Avatar
BoomerZ33
got pics of Miata?
Old Aug 4, 2012 | 08:53 AM
Mcutali's Avatar
Mcutali
Talking mx5 build
Originally Posted by BoomerZ33
got pics of Miata?
Well Being its 350Z site I wasnt going to throw any up, but heres a few from the build.
heres the block from the machine shop, she was hot tanked,shot peened, re honed and I had her coated crinkle black. Fresh Brass Freeze Plugs.
here I use a Acetylene torch to burn out all the old bushings from rear diff and all suspension arms.
Heres the Motor fresh out of the car, disgusting.
Oil Pain Dran -10an tig'd on
completed motor(cometic .80mm headgasket,Eagle rods+Arp2000s,Arp main studs, Arp head studs,Clevite Race bearings thrust washers, rx7 550cc injectors, crankshaft from a 1993 1.6l, coilpacks from the 4age,Flyin Miata Happy Meal Clutch Kit and Flywheel, Itm Oil Pump, Gates Water Pump, Gates Kevlar Belts. Pistons are stock and have been ultasonically cleaned. Dnj Engine Components Piston Rings.)
sweet gates kevlar belt
Cage
Theres alot of new pics I need to put up, I have wire wheeled the entire car of seam sealer. Getting ready to spot weld everything for rigidity. Once thats complete car is heading to the body shop.
Old Aug 4, 2012 | 10:11 AM
man03999's Avatar
man03999
Welcome Back!
Old Aug 4, 2012 | 10:38 AM
DB350's Avatar
DB350
mind me asking what the cost is of this? ballpark? looks good
Old Aug 4, 2012 | 03:04 PM
Mcutali's Avatar
Mcutali
Wink
just to build the motor? im currently rebuilding the entire car. every suspension arm was bead blased and coated.
engine bay has had every little thing removed, and cleaned up, shaved.
underside of car was pressure washed with purple power, hand scrubbed, and coated with 3m Underbody coating, small fortune in 10$ cans
interior is gutted, 6 point cage xbrace and harness bar.
Ive probably got like 5k in the entire build if that? with purchase of car. I should of been keeping better track.
I collected part for 6 months for a 200hp build, last minute i wanted 250+ lol
I'd say I have 1k in that motor maybe a little more? Ive sourced everything at reasonable prices off forums and via friends.
Old Aug 4, 2012 | 04:09 PM
Flo-ridaZ33's Avatar
Flo-ridaZ33
Looks nice.
Old Aug 4, 2012 | 07:44 PM
Mcutali's Avatar
Mcutali
Default re
Originally Posted by Flo-ridaZ33
Looks nice.
thanks appreciate it, hopefully in the next year ill be posting some vq builds.
flo-ridaz33 hit up All Florida Z's on facebook
my 350z
Old Aug 6, 2012 | 05:42 AM
JDSMotoring's Avatar
JDSMotoring
Vendor - Former Vendor
looks good well done
sales@czp
Sep 23, 2019 03:30 PM
_bit
Oct 2, 2015 07:49 AM
Depravity
Oct 1, 2015 04:49 PM
