Best Used MY 350z
Old Sep 26, 2012 | 11:17 AM
kyoo's Avatar
kyoo
Default Best Used MY 350z
Just wanted to see what the consensus was for the best used model year 350z - it seems 2003 is more or less out due to the transmission problems, and 07+ is preferred for the HR motors.
Doesn't seem to be many threads compiling the data, just a lot of threads posting about their various transmission problems.
FYI, new to the forum, fairly new to 350z's, just considering picking up a used 07+. Have an 06 Evo 9 in the garage that I'll keep, just looking to get into a solid rwd car for autocross.
Seems enough data is out to suggest that the 2008 350z's are a little more reliable in terms of trans and a few other issues the 07 may have had.
Thanks
Old Sep 26, 2012 | 11:40 AM
terrasmak's Avatar
07 and 08 are best, but i would have no problem buying another 03 to 05, just no 06 rev-up oil burners.
Old Sep 26, 2012 | 11:57 AM
KingBaby's Avatar
KingBaby
Hardest Setting
your own assumptions are correct
Old Sep 26, 2012 | 12:51 PM
Pengu's Avatar
Pengu
Everyone hates the 06 . No problems with mine but admittedly you are taking a chance buying the Rev-up engine.
Old Sep 26, 2012 | 02:44 PM
kyoo's Avatar
kyoo
thanks for the inputs guys - from what i've seen i guess the 07s had transmission issues time to time but the 08s seem fairly reliable
Old Sep 26, 2012 | 03:06 PM
805350z's Avatar
805350z
03 if the trans problem was fixed. I'm on my orig trans in my 03 with 92k
Old Sep 26, 2012 | 06:00 PM
707_Z's Avatar
707_Z
I just got my 03 not too long ago, no real problems with it minus the trunk shocks which was an easy replacement with ebay parts. The 03's seem to run cheaper probably because the transmission problems
Old Sep 26, 2012 | 07:12 PM
Zesty's Avatar
Zesty
might as well aim for an HR, they seem to be pretty cheap nowadays.
Old Sep 27, 2012 | 12:06 AM
KingBaby's Avatar
KingBaby
Hardest Setting
If it's just for autocross...then go with the 03. You can probably find one for 8k
Old Sep 27, 2012 | 12:58 AM
BrickyardZ2003's Avatar
BrickyardZ2003
Obviously most 03's out there can be had for around and under 10k. For what it's worth, mine is creeping up on 90k with the original transmission and clutch, without any grinds or issues.
Old Sep 27, 2012 | 05:44 AM
dykel3fiddyz's Avatar
dykel3fiddyz
I have 07.
Most say the 08 was the best 350 made.
Old Sep 27, 2012 | 07:08 AM
Nismo350z#0310's Avatar
Nismo350z#0310
07 or 08. Period. Owned a 05 and now own a 07. HR Zs are miles ahead in styling, engineering and power.
Old Sep 27, 2012 | 09:16 AM
kyoo's Avatar
kyoo
Thanks for all the input - been reading the highest mileage HRs thread, seems like it would be really hard to know the TRUE state of the car no matter the miles - so many things that seem to be going wrong.
If the car's in a different state I'd need some detailed pictures of things.. And even then it would be difficult to know how, for example, the window motor is, the clutch sticking to the floor, bushings, endlinks, control arms etc... These things aren't necessarily exclusive to used Z's but the Z's do seem to have more issue with them.
Old Sep 27, 2012 | 09:31 AM
tylerxfire's Avatar
tylerxfire
never had an issue with my 03 and i actually put power to it
Old Sep 27, 2012 | 09:33 AM
hookah's Avatar
hookah
Thanks
Even if it did have problems, I am sure it would have been fixed by now. Its been like 10 years. My Manual 03 is running strong thankfully.
Old Sep 27, 2012 | 10:12 AM
kyoo's Avatar
kyoo
as in used z's would all have been upgraded to the cd009 trans by now? possibly, but kind of hard to tell before seeing the car in person
Old Sep 27, 2012 | 10:20 AM
KingBaby's Avatar
KingBaby
Hardest Setting
as in the previous owner would have fixed it
Old Sep 27, 2012 | 10:30 AM
Bmurray350z's Avatar
Bmurray350z
Ditched my 04 for an 08 and love it.
Old Sep 27, 2012 | 11:15 AM
!Z!'s Avatar
!Z!
I had a 03 and now i have a 07 i love the HR motor but i think i want a v8 LS series engine now. So PM if you want to buy my HR 07 350z
Old Sep 27, 2012 | 12:13 PM
mike_350z's Avatar
mike_350z
i love my 06, only complaint is that the transmission is a little sloppy
