Nismo Aluminum Fuel Cap
Old Jan 13, 2004 | 04:52 AM
RJW0501's Avatar
RJW0501
Default Nismo Aluminum Fuel Cap
Dosn't fit.
Too small, has anyone else run into this?
Old Jan 13, 2004 | 05:33 AM
kitkos's Avatar
kitkos
You are correct.
I used my Dremmel tool and removed the plastic lip around the top of the OEM gas cap. Then used two screws that were longer thatn the set-screws that came in the Nismo cap.
Be sure they are not too long to keep the cap from ratcheting.
Old Jan 13, 2004 | 05:53 AM
RJW0501's Avatar
RJW0501
good idea, thank you.
Old Jan 13, 2004 | 05:58 AM
Blownaway's Avatar
Blownaway
I would also use epoxy to make sure the bond is tight
Old Jan 13, 2004 | 09:15 AM
kitkos's Avatar
kitkos
The top of the Cap has a ratchet effect. Once it is tight the cap will continue to turn without over-tightening the piece that screws into the gas filler tube.
I wouldn't use any epoxy because it might stop this from happening.
I have had mine in place for a few months with only the two screws and it works perfectly.
Old Jan 13, 2004 | 09:29 AM
BrickydZ's Avatar
BrickydZ
Default Epxoy
In order to get it to fit, you have to get the upper lip off.
Dremmel will work, grinder. I took a stain glass soldering iron and burned mine off, then sanded smooth. doesnt matter how you do it. You just have to get the top lip off. Then the silver cap will mount flush to the bottom black lip. The mounting of the silver cap will cover over all the mistakes you made in cutting the top lip off.Then I mixed up and put some epoxy on top, then installed the cap, screwed in the screws and wiped off the excess epoxy.
I had seen two others before I did mine, and believe me,it works.
Also you dont have to worry about the ratchet effect.
The black cap is solid, with the rachet effect in the white section only. The white section can be removed,(with a little prying with a screwdriver) and reinstalled with no effect of the ratchet.
It is not neccesary to remove the white but you can if you want.
Just so you know a replacment cap is like $12.00, so I ordered one, and experimented with the other.
Give it a whirl. you wont be sorry.
Old Jan 13, 2004 | 12:33 PM
ajk4's Avatar
ajk4
any pics of the finished product kitkos? i've yet to even see the gas cap being sold anywhere so any pics/links would be appreciated.
ajk4's Avatar
ajk4
Old Jan 13, 2004 | 12:56 PM
RJW0501's Avatar
RJW0501
Old Jan 13, 2004 | 04:44 PM
lowrider's Avatar
lowrider
You know, you'd think they would make something that would fit without modifications. Does anybody know of a chrome replacement gas cap that will fit?
Lou
Old Jan 13, 2004 | 04:58 PM
SweatyPalm's Avatar
SweatyPalm
I'm new to this Aluminum Fuel cap thing....I have never seen one but I have a safety concern. Will this fuel cap cause any sparks due to static discharge? I have heard too many accidents about ppl touching the gas nozzle.
Old Jan 13, 2004 | 05:31 PM
kitkos's Avatar
kitkos
Here is the link to the cap at Courtesy Parts
The cap fits over the top of the OEM gas cap, you know, the one that came with the car.
Sweaty - It is chrome. The nozzle on the gas pump is aluminum, no safety concern.
lowrider - Exactly the same thing I said to Richard at Courtesy Parts right before I said "ship it". It's $50 worth of bling plain and simple.
ajk4 - sorry for the bad image. it's night in my garage.
Old Jan 13, 2004 | 06:06 PM
kitkos's Avatar
kitkos
can't seem to get the imge to post. let's try again.
can't seem to make the image upload tonight. tried 2 different computers so it's not on my end.
I'll try again in the morning.
Old Jan 13, 2004 | 08:38 PM
BrickydZ's Avatar
BrickydZ
Why they decide to make the Z cap different than all the rest I do not know. A standard generic nissan cap will fit all or almost all models, but the Z cap is different than them all. I found this out when I went to get a 2nd cap to cut on.
The only thing that I can surmise is that the cap must be firmly seated before the fuel pump can get suction to work, or it has something to do with the gas mileage/fuel consumption function on the digital readout. In order for it to make the read out, the fuel cell system has to be closed, and therefore the specialty cap with the different rachet mechanism closes more tightly.
But I will be the first to admit, I dont know for sure. Purely speculation on my part.
Old Jan 14, 2004 | 04:36 AM
kitkos's Avatar
kitkos
OK, I am going to try to post this picture from work. Hopefully this will work.
OK, the site is messed up again. 3 different computers 2 different locations. Go figure. Sorry I can not post the image.
I'll let Victor know.
Old Jan 14, 2004 | 02:58 PM
kitkos's Avatar
kitkos
Last try...
Old Jan 14, 2004 | 04:35 PM
vfr350's Avatar
vfr350
That should make it go even faster..............
Old Jan 14, 2004 | 04:44 PM
Reggi914's Avatar
Reggi914
Its nice, i like it.
Old Jan 15, 2004 | 08:24 AM
RJW0501's Avatar
RJW0501
Thanks all...I used a grinder to grind it down....I did have to use epoxy....the screws are useless.
