Gtx35r with a 106. AR plz help
Old 03-12-2013, 07:09 AM
cris6818
cris6818's Avatar
Default Gtx35r with a 106. AR plz help
Hey guys I just bought a gtx35r with a 106 AR housing . How bad of a spool time you think ill receive? I have a 06 built with cams with a haltech stand alone
Do you think I should use a 106 AR housing ? For my almost 4.0 liter displacement ? Or should I put back on the .82 AR housing ? My hp goal is 600+ I've made 500 wheel on a gtx30/.82 AR why I had this turbo is because I guess when I purchased the powerlab kit from intense power they sold me a gt30 what was suppose to be a 35 which it isn't . Ordered a real gtx35 now I need advice please guys thanx. I can post pictures of both turbos for comparison to what powerlab sold me
Old 03-12-2013, 09:57 AM
str8dum1
str8dum1's Avatar
you will get the best results if you just try both housings. its not that hard to swap on the PL kit.
On a T3 turbo, i'd just use the 1.06 but you never know until you try it.
Old 03-12-2013, 10:00 AM
thatv35guy
thatv35guy's Avatar
Don’t waste your time with the .82 exhaust housing.
I had the .82 exhaust housing on my car; I essentially maxed out that turbo on pump gas (AZ 91) at 470whp… I recently upgraded to the 1.06 housing, going back to the dyno in two weeks…
A friend was running the 1.06 exhaust housing on his GT35R/PL kit and he made 52x on pump gas (stock exhaust too) and 600+ on E85.
I think the difference in spool will be less than 500 rpm too.
Old 03-12-2013, 10:23 AM
graffkid732
graffkid732's Avatar
Why don't more Z guys look into the QSV from Sound Performance if worried about when they will start to spool?
Old 03-12-2013, 10:35 AM
thatv35guy
thatv35guy's Avatar
It’s really not worth it on a T3 turbo, there’s hardly any lag on my setup.
Old 03-12-2013, 10:41 AM
bmyles
bmyles's Avatar
So you received a gt30 from Intense Power and they made you buy a gtx35 instead of making it right? That's a lot of dough.
Old 03-12-2013, 10:44 AM
Resmarted
Resmarted's Avatar
1.06 is a WAY better choice for a 4 liter setup than a .82. For 600hp that's the housing I would try first!
Old 03-12-2013, 12:56 PM
jerryd87
jerryd87's Avatar
better then that why are people going full tilt with cams and crap if worried about spool. Stock cams will handle 600, I made that at 5200 through a slipping clutch and much bigger turbo.............and a 3.5L no reason shouldn't be able to do it with a 4.0 even with a slightly higher compression and tighter engine
Old 03-12-2013, 02:18 PM
Elperuano
Elperuano's Avatar
Hurry up n get that monster running so we can run it!
Old 03-13-2013, 05:02 AM
djamps
djamps's Avatar
nice turbos.
Old 03-13-2013, 06:22 AM
meatbag
meatbag's Avatar
Would need to be a divided manifold/turbine housing
Old 03-13-2013, 07:46 AM
jerryd87
jerryd87's Avatar
only turbine housing, divided manifold wont work with a qsv
Old 03-13-2013, 07:47 AM
meatbag
meatbag's Avatar
Your right, was having a brain fart.
Old 03-13-2013, 09:58 AM
jerryd87
jerryd87's Avatar
we all do sometimes =P
bugz
04-09-2004 03:11 PM
dchi_t
08-24-2003 08:53 AM
bugz
06-21-2003 11:51 PM
Zb4-18
09-08-2002 07:04 AM
Quick Reply: Gtx35r with a 106. AR plz help
