Alternator question
on
on
ok well seeing as how we have a 115A alternator, i think he will be more than ok (moms Audi S4 has like a 90A alternator and she has way more power components than us)
Yea I have a small system in my z but my lights are dimming and yet my voltage stays at the 4th mark.
2 12" jl audio wxv2 4ohm subs
Jl audio 300/2 wired down to 2ohm load.
on
Because that is extra components your car didn't expect to run, as in it didn't come stock, dimming lights aren't anything bad. Grab a small kinetic battery if the lights bother you that much.
http://postimg.org/image/tumnawm03
do you think it could be the ground i took the car in bestbuy to have the stuff installed. i told the guy to install the amp where the stock sub goes into and he put the ground inside the area as well but i am not sure if it is a good enough place.
dimming lights is a big thing! it means that your pulling more aps than the car an produce so it steals from any available source (lights, sensors, ecu.) get yourself a cap and the dimming will go away. a cap helps out to give the amp the extra power that the normal electrical system can't handle.
