My new Z almost cuts out at around 4500 rpm?
on
Ok, now that it is broke in, every now and again as I cross 4300-4500 the SLIP light comes on and the engines lets off pretty quick. I am getting good traction. I cant figure it out and it only happens about 1 out of every 4 times. Anyone have any ideas??
Matt
Matt
on
rev limiter? You can't set the rev limiter on the Z, only the "shift light" on the tach.
Anyway, are you getting on it hard when this happens? Or are you just driving and shifting normally? If you're really stepping on it, then it very well might be that your rear is breaking loose, if not, then I'd get over to Nissan and have them check out the TC.
on
Try slowly and smoothly revving up to 5K...if it happens when you do it lightly you should have the dealer check it out
also try it in neutral...if it happens in neutral you def hav a problem
on
Oh well.... thought you could adjust it. Never messed with that feature.
on
Rev limiter (the one I adjust) is turned up. I was under the understanding that, the adjustment just flashed the light and would not affect engine.
on
MAsSIVrOOM
10-20-2023 10:50 AM
Justin100
11-29-2015 03:58 PM
Tochigi_236
09-27-2015 03:40 PM
Extreme Dimensions
Southern California
09-24-2015 03:35 PM
