Non vs rev-up >.>>>....>>>>>
Old Sep 7, 2013 | 09:44 AM
S142jzkillav10's Avatar
S142jzkillav10
Angry Non vs rev-up >.>>>....>>>>>
I was looking at specs. And only came up with the difference of the Non vs the rev-up is the Intake plenum. The non has longer runners and the rev-up has Shorter runners.
What I want to ask you fellas about the internals.
Are they all the same ??
Does the internals make the motor rev faster ??
I recently purchased a 2006 Z and has the rev-up motor ( motor is seized up ) I purchased a NON Rev-up motor So my intent is to just swap out the plenums.
Thanks for the help.
Old Sep 7, 2013 | 09:53 AM
freddys 350z's Avatar
freddys 350z
ecu is different...the rev up had cam phase for the intake AND exhaust..non revup is just intake...
you might need the non revup ecu...or just send the the non revup and buy a revup.
Old Sep 7, 2013 | 10:13 AM
S142jzkillav10
I have ecu and wire harness for both. So your saying that the rev-up ecu will not work with the non-rev motor ?? The engines have different sensors ?
Old Sep 7, 2013 | 10:16 AM
freddys 350z
yes..i cant say it will be a strait swap. your best bet is to just get the correct motor and sell the non revup.
Old Sep 7, 2013 | 10:52 AM
S142jzkillav10
ok thank you for the info. Guess I'll have to start looking for the rev up. Redline starts at 7k correct Vs the non rev 6800 ??
Old Sep 7, 2013 | 03:55 PM
terrasmak's Avatar
Holy crap, there is a lot of info on here about this. Just search a little bit in the engine section.
Old Sep 7, 2013 | 05:37 PM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
Wish my red line was 6800
Old Sep 7, 2013 | 07:41 PM
samsniss350z's Avatar
samsniss350z
I wonder if the Rev-up motor seized because of the high oil consumption some of these engines suffered from?
Old Sep 8, 2013 | 07:47 AM
S142jzkillav10
Seems like that is what happened to this one. I did check the dip stick. Had oil but I guess it was too late when they added oil. Motor was already locked up.
torchkc
Sep 11, 2015 08:26 PM
marques1
Aug 25, 2006 02:25 PM
frostyrock7c
Feb 17, 2006 08:40 AM
alex30327
Dec 24, 2002 06:47 AM
