Noise when pressing gas from a 45 roll??????????
OK i was on an open straight road (alone) and i was running about 45mph.....then i gunned it and as i did i could hear a resonating sound from the passenger side of the car. I turned off into my school and looked the the door behind my seat and all i have in there is the owners manual. any ideason what it could be???????????????
thanks guys
landon
thanks guys
landon
If you looked in the glove box then it is possible it may be the fuel pump since it is in the tank under the glove box. I doubt that the noise came from there though. Did it sound like an exhaust sound?
if you can imagine this it sounds like some thin piece of aluminum hitting something...if youve ever had a fan shroud go loose then its kinda like that.
If it is the pump what can you do about that???
i was in school this morning reading the motor trend from Nov of 2003. At the back of the "one last year" update the Z was mentioned. And it included some problems that were incountered and this is what was said "we noticed a metallic grinding noise from the rear of the Z and had it checked at the last service. Both rear-brake backing plates were loose and were tightened gratis by our dealer."
So anyone had this problem
landon
landon
MAsSIVrOOM
Oct 20, 2023 10:50 AM
liqalu04
Jan 2, 2022 12:58 PM
