Tsb's
on
Charter Member #103
on
Good Dr.
Perhaps you can help a fellow Charter Member out.
Looks like my car is involved in the first recall.
Due to a rainy summer of 2003 and horrid winter of 2003-4 my 17 month old Z has only 4100 miles on it.
The tire feathering has just started.......rumor is a true fix is coming soon so I am waiting to handle that problem.
My Bose is fixed and the window streaks aren't that bad.
I was just wondering what other problems I could looked at during the recall service.
Thanks alot!
Thanks alot!
Charter Member #19
Well, since you have the Touring you have leather so you don't have to worrry about the cloth seat TSB
NTB02-070a is the tire pressure sensor TSB but if you have no trouble with this I would certainly leave well enough alone.
NTB02-071a is for the vehicle immobilizer so if your car is starting no need to worry there.
NTB02-097b is for a buzzing noise from under the hood only when the AC is on.
NTB02-098 is for windshield washer fluid seepage.
NTB02-100a is if your tire pressure light stays lit all the time.
NTB02-102 is if your gear shift **** is on ****-eyed (standard only)
NTB02-122 is for various squeaks and rattles inside the cockpit.
NTB03-001 is if your interior courtesy lights don't work right.
That's about it if you aren't going to worry about the feathering, the grease streak or the Bose.
Originally posted by Dr Bonz
Which ones are you interested in. I may be able to get them for you.
Do you have a copy of the actual TSB for the seat moving or clicking? It is happening in my 2004 track and I am VERY hesitant about bringing it to the dealer and letting them tear it up. I'd like to have some docs in hand. I have the number but not the actual TSB pdf. Its NTB03076. Is there a new one for 2004's? Thanks!
Charter Member #50
on
called dealer to see if they can perform cloth seat tsb, but dealer said it's not guaranteed.. they have to let manager approve it first... isn't tsb is mandatory? or it's opional for dealer to decide if they want to do it or not??
on
from http://trucks.about.com/cs/truckreca...b_glossary.htm
Definition: A bulletin issued to an auto dealer by the manufacturer detailing a fix for a known concern. The bulletin is for informational purposes only. It is not a recall. The dealer is under no obligation to make the repair or notify customers. TSB's are intended to assist dealers in ongoing repairs.
on
A more current list is available here:
http://www.350zfrenzy.com/forum/view.php?pg=350zinfo
Right-click to save the file - it's updated through 2/10/04.
hth
hth
hth
hth
s9am_me
04-23-2003 05:09 PM
