Whats the consensus on the release/throw-out bearing issue?
Old Apr 9, 2015 | 01:09 PM
Moe747's Avatar
Moe747
Default Whats the consensus on the release/throw-out bearing issue?
What is the preferred or recommended method of dealing with a noisy/potentially worn throw-out/release bearing? I bought my car about a month ago and this noise just appeared as soon as I bought it and I decided to read up on it. It seems that there are mixed responses to this, people are saying you need a new clutch, others say that it's a normal thing. I asked my mechanic and said it needs a new clutch.
Old Apr 9, 2015 | 01:29 PM
clubhopper's Avatar
clubhopper
New TOB but while you are at it new clutch because you are in there anyways. Go get the upgraded pivot pin too.
Moe747's Avatar
Moe747
My car sounds exactly like this:
Old Apr 9, 2015 | 01:53 PM
Moe747's Avatar
Moe747
This? https://conceptzperformance.com/Cart...on.php?II=2478
I'm going to get the long version of it.
Old Apr 9, 2015 | 02:35 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
Nowhere in your post nor on your profile do you specify what year Z. Good to include that when asking for help.
Why? Well, there are known problems and/or better parts varying from year to year. To wit:
Up to '06, you might be able to get away with just the throw-out bearing but agree with clubhopper that you may as well do the clutch since you're in there anyways. (Or at least the friction materials if it's relatively new and the pressure plate is still OK) (And of course, vice versa.... replace T/O bearing and pivot & arm if replacing the clutch.)
On the '07-8s, DEFINITELY do the internal slave/release bearing (as well as the clutch/friction components). Nissan's OEM part is junk and a known problem. Generally recommended solution is the Z Speed unit.
Oh, and while your mech is in there, s/he should check the trans input shaft because there's a 50% probability that that is the source of the "rocks in the clutch" rattling sound, not the release bearing. (50% because it can go either way or both.)
Mic
Old Apr 9, 2015 | 02:36 PM
Moe747's Avatar
Moe747
Mic
Sorry, I have the 2003 Touring model.
Old Apr 9, 2015 | 03:38 PM
MicVelo's Avatar
No worries, I figured it out from that pivot you selected.
Old Apr 9, 2015 | 04:03 PM
Moe747's Avatar
Moe747
Alright so if I go ahead with the clutch and bearing replacement how long would it be before this issue comes up again? I've read that people with this issue change their clutch and that this same issue comes back before a thousand miles. So does that happen often? If it does would you have to replace the clutch again?
Old Apr 9, 2015 | 05:46 PM
MicVelo's Avatar
Moe, what you need to do is take it to someone who knows Z cars and have them give a complete diagnosis versus having someone look at it and determine the "whole problem" is a bad clutch - and that diag is ascertained by looking at the wear of the clutch disk.
I can say with some degree of confidence that while your clutch may be worn, I doubt it's the source of the entire problem. Maybe yes, maybe no but the point is that it sounds like the person who diagnosed it is a "throw parts at it" technician. Not to diss him/her as they might actually be competent and I'm the idiot, but it sounds too pat.
If the problem comes back in a thousand miles, well, faulty diagnosis, no? And will the shop just throw more parts at it figuring, "Well, by process of elimination......"
Far be it for me (or any else here) to render a foolproof diagnosis without putting hands on it. But I suspect there's more to it than a worn clutch. Maybe the fork is misaligned or bent (which I recommended changing while doing the clutch.)
Point is, "get a second opinion".
Mic
Old Apr 10, 2015 | 02:26 PM
blufc3s's Avatar
blufc3s
When I got my 03 touring Z it had/has that exact noise and symptoms for the first 30 seconds or so when the car is cold, then completely goes away.
I changed the clutch PP, and TO bearing, put it back together and the noise is still there, didn't make any difference and the original parts look fine.
It was 18 months ago when I changed everything. I just start it up in neutral with the clutch out when it's cold and drive away.
If your problem is only occurs when the car is cold (eg. Sitting overnight) and goes away after a few seconds I would just drive and enjoy!
Old Jun 23, 2015 | 09:33 AM
05track_Z's Avatar
05track_Z
I have the same problem in my 05 track edition after a buch of research i got the same answer... Its normal the dual mass flywheel is super noisy theres a couple companys that offer quite option with their clutches specifically for the z
Obadabot
Jun 18, 2023 11:31 PM
burglapfd
Dec 6, 2020 01:04 PM
350z82
Oct 1, 2015 06:25 PM
samansharif
Sep 25, 2015 12:31 PM
