Fuel smell in engine bay
Old Apr 10, 2015 | 06:32 AM
bluz370's Avatar
bluz370
Default Fuel smell in engine bay
Hi guys,
I need a little help as I have a drift event this weekend and there is a slight smell of gas in my engine bay. It is more prominent on the passenger side, and it is coming from under or right behind the throttle body per my nose.
My car is a 2008 350z with 90k miles. It has kn filters testpipes and Greddy exhaust as the only engine mods. I have driven almost every car I have owned with TP or DP, so I know that they smell a bit. This is a FUEL smell that is prominent IN the engine bay.
I have a few questions:
1. Has anyone ever had a fuel smell from this area and can you tell me what you did to fix it? I am thinking leaking injector or line, but when I turned the car on to prime, no fuel was present.
2. If an injector O-ring was not sealing properly and spraying fuel incorrectly, would I get a cel for a misfire on that cyl? I would think yes, but so far I dont have any.
Any help would be appreciated
Old Apr 10, 2015 | 07:57 AM
rustyschopshop's Avatar
rustyschopshop
You make want to check the fuel dampers at the end of the fuel rails. There are orings there that may need some attention. Also check fuel lines for crack even though that is not typical of our z's.
Old Apr 10, 2015 | 08:16 AM
monztr's Avatar
monztr
I can't speak to the HR but the DE has the vapor recovery line with valve and cap on the passenger side near the firewall and battery box along with the fuel supply line which attaches to the rail with an O ring's fitting a the fpr. Assuming they are the same I'd have a look at that fpr where the line attaches and at the vapor recovery valve.
Old Apr 10, 2015 | 09:51 AM
bluz370's Avatar
bluz370
is the vapor recovery valve the one with the "green" cap on it? I will tear into it to check this evening. Thanks for the direction. I really appreciate it.
Old Apr 10, 2015 | 09:54 AM
bluz370's Avatar
bluz370
If it was an injector o-ring I would be getting a misfire code correct?
Old Apr 10, 2015 | 10:30 AM
bishop_98's Avatar
bishop_98
To my knowledge, not immediately.
Old Apr 10, 2015 | 12:05 PM
monztr's Avatar
monztr
Yup, green cap on the vapor line.
Old Apr 10, 2015 | 07:30 PM
rustyschopshop
Not always true.
It would be extremely rare for the schrader valve on the evap port to leak unless it was recently checked but always possible. If it is from the evap, I would be more apt to trace back from the service port down near the exhuast manifold and see if the line came out of the retainer bracket and melted on the exhuast.
Old Apr 11, 2015 | 07:48 AM
terrasmak's Avatar
I know a few of us with de cars have cracked fuel rails.
3vilbunny
Jul 18, 2017 05:10 PM
