i am going to cry
Guys please help
A clunking sound the sound like and from the point where the wheel is not scrwed down at the front at low speeds over bumps.
i have had the 350z at japex and we have changed the banana arms on boths sides and still the sounds is there.
what are all the areas to check becuase this has just cost me 800 and not fix.
please someone help im so stressed out with this problem as the cars feels solid and it just this bloody clunk clunk rhs wheel arch.
Need more info.
Did you change the suspension in any way? New shocks often need to be re-tightened after they are put on and driven some miles.
A bad LCA bushing can make this noise.
Are you lowered at all?
Does the clunk seem speed up and slow down with speed? Or reciprocal is how they'd term it. Because if so it has to be something that rolls i.e wheel, tire, bearing, axle, etc.
How are your end links? If they are real bad it can cause major "clunking" noise especially low speeds. I replaced mine recently, was worried about ball joints, etc. but this completely solved my issue and silenced that noise. Good luck with it all.
What is a lug end? And just to clarify it just sounds like the wheel is lose the steering and handling is tight and solid it just seems be be whenever the wheel has negative up force it bright of car lifted monetarily the clunk clunk clunk occurs
Could be the lower control arm bolt has loosened, bushing in the LCA (lower control arm), other options of course...nothing to freak out over whatsoever...but you have to get it looked at soon...nothing with loose suspension parts ever gets better or fixes itself.
Just get a free inspection and ask around for a good mechanic...should always have a good mechanic in your contacts as used cars will always develop an issue beyond your capabilities at some point or another.
Saved
Saved
