1st Gear- stiff?
Old Sep 18, 2002 | 04:09 AM
ethan84ae's Avatar
ethan84ae
Charter Member #35
Default 1st Gear- stiff?
Sometimes it takes me a few attempts to get the gearbox into first gear (6-speed) from a stop...has anyone else had this problem? I've only got 400 miles on the odo, so I'm assuming that the car just needs to broken in a bit more?
Otherwise the gearbox feels like a million bucks....
Ethan
Old Sep 18, 2002 | 04:15 AM
j's350z's Avatar
j's350z
Hey Ethan,
Did you take pictures of your car in front of the Hyatt in New Brunswick. I saw some pics online and told it might of been yours. I work their and I am still waiting for my CS base from Acme.
Just wondering
Jason
NJ
Old Sep 18, 2002 | 04:18 AM
VandyZ's Avatar
VandyZ
Yes, I would say one out of very ten tries I have trouble. I have not figured out what I am doing to cause it to happen. I think I may just be missing the gate. Let me know if you figure anything out.
Old Sep 18, 2002 | 04:22 AM
padam07's Avatar
padam07
Default You might be missing
You might be missing the gate. If you have trouble putting into 1st, try putting it into second then put it in to first. I have to do do this to my MR2 when I have trouble.
Old Sep 18, 2002 | 04:29 AM
ethan84ae's Avatar
ethan84ae
Charter Member #35
Originally posted by j's350z
Hey Ethan,
Just wondering
Jason
NJ
That was me. The entire set is here:
http://www.imageevent.com/ethan84ae/350zday3
Did you see the pics posted somewhere besides at the above link or on my350z?
-EThan
ethan84ae's Avatar
ethan84ae
Charter Member #35
Default Re: You might be missing
Good idea- I do that once in a while and it works- hope I won't have to in the long run though...
Old Sep 18, 2002 | 04:30 AM
ethan84ae's Avatar
ethan84ae
Charter Member #35
Default Re: try this
Originally posted by crawdaddy
be sure your moving the shifter to the extreme left before pushing to 1st gear. There all a little stiff going into first.
I think I'm doing that- but maybe I need to be a bit more concious of it... will keep in mind, thanks.
Ethan
Old Sep 18, 2002 | 09:46 AM
rouxeny's Avatar
rouxeny
I found that sometimes, it's tough to get into first because I haven't depressed the clutch all the way. The last half inch or so of travel seems important. It also helps if the car is completely stopped. If you're still rolling, even very slowly, it grinds a little going into first.
Old Sep 18, 2002 | 10:03 AM
Chris's Avatar
Chris
Try letting the clutch out in neutral then pushing it in and shifting into first. Sometimes this happens to me in my aunts car it just has to deal with the shaft inside spinning at the right speed or something.
Old Sep 18, 2002 | 10:12 AM
Killermove's Avatar
Killermove
I sometimes have this trouble too. Although, I think it is getting easier. I picked it up yesterday (11 miles on it) and drove it 160 more. This morning it seemed easier to slide in there.
Although, I will agree, the last 1/2 - 1 inch of clutch travel is of upmost importance. The clutch engages VERY soon. Caught me off gaurd yesterday because the manual cars I've learned in and driven had much high engagement points (almost all the way out).
Ryan
MAsSIVrOOM
Oct 20, 2023 10:50 AM
sherm
Apr 11, 2020 05:21 PM
seagrasser
Oct 11, 2015 03:27 PM
