Navagation
Old Aug 12, 2016 | 04:07 PM
Katylouise's Avatar
Katylouise
Default Navagation
I'm just wondering if you can remove the Navagation system from an 05 350z
Old Aug 12, 2016 | 04:54 PM
Arrtus's Avatar
Arrtus
You can do anything if you believe hard enough... and yank even harder.
I'd assume it would be the same way as removing the radio; from the back after removing the console.
Here's a link to give you a basic idea: http://liljerk.morpheus.net/350Z/dash_removal/
Old Aug 12, 2016 | 05:42 PM
travlee's Avatar
travlee
Master
how would you fill the big open void?
Old Aug 12, 2016 | 05:45 PM
Katylouise's Avatar
Katylouise
Make it a cubby?
Old Aug 12, 2016 | 05:49 PM
travlee's Avatar
travlee
Master
i would make sure that you could before you rip it out.
Old Aug 12, 2016 | 06:01 PM
Katylouise's Avatar
Katylouise
Can't you just buy a cubby and put it in ?
Old Aug 12, 2016 | 06:03 PM
travlee's Avatar
travlee
Master
i have no idea, i would reach out to courtesy parts... or look on their site to see if the part number for that area are the same
Old Aug 12, 2016 | 08:15 PM
NiLL's Avatar
NiLL
You would need the whole top center stack from a non nav car..... And the cubby. If you have a slidy button cubby make sure your car has a whole center stack (all of it) from a 2006+.
If you have a pushy button cubby make sure your whole center stack is 2003-2005.
Since you have a 2005 already you would only need a 2003-2005 Upper center stack and cubby.
(its going to be a lot of money)
Old Aug 15, 2016 | 10:28 AM
CK_32's Avatar
CK_32
Its possible. I know a bunch of people who have taken OEM nav out for a newer one.
Idk how tho. But it is possible. But if I know about working on interior. Which I do.. It will be a pain in the azz, end with some broken or bent brackets, and lots of cussing and "wut the fck is that!? And where the fck is it connected to!?"
Old Aug 16, 2016 | 02:02 PM
stendori's Avatar
stendori
i have just the opposite issue where i want to add nav in my car, but it doesn't sound like it's worthit for a oem version. i did see a cubby on ebay a week ago for sale.
Old Aug 16, 2016 | 02:03 PM
travlee's Avatar
travlee
Master
Why dont yall swap?
Old Aug 16, 2016 | 02:42 PM
Spike100's Avatar
Spike100
Hi Katy,
You can remove the OEM Clarion navigation unit from an ’05 350z. It’s not difficult. You will need an instrument cluster and cubby section to replace the one you are removing.
There is a great deal of wiring in your OEM navigation equipped car, but you can just leave that in place.
Questions:
  1. Are you also planning to replace the Bose H/U?
  2. Is your OEM navigation unit working? I’m wondering why you want to replace the stock navigation.
--Spike
Old Aug 16, 2016 | 06:39 PM
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
I went and looked at a car with navigation a few weeks ago... I wasnt aware that you push the button and it opens automatically... With the car off I pushed the button nothing happened so I pried that ***** open...
Oops.... Didnt buy that **** anyways. Anyways just take it apart and play with it... You will figure it out
Zajac
Wheels Tires
May 6, 2016 02:33 PM
yosip1115
Apr 15, 2016 11:26 AM
Grievous3
Apr 1, 2016 05:24 AM
alawoowoo
Sep 29, 2002 08:32 PM
