350z in Vegas heat
Well. I moved to Las Vegas and my car after running for a little seems to run like **** due to the heat here (100+) . It'll also occasionally overheat a bit (but nothing too major) Any opinions on what needs to be added to run better here?
thanks to anyone.
thanks to anyone.
Put the stock air box back.
Pop charger does make it slightly sluggish on a hot day until the inlet temp comes back down to normal. Even my minivan feels sluggish in the summer here, 115 degree day and the air off the blacktop is 160ish. You lose about 3 ho for every 10 degrees added.
I'll add to the "Put your stock airbox on"
I had the JWT Popcharger on my 350Z when I was living in Palm Desert CA (Extremely similar temps, if not the same). Sitting in traffic on a hot day and the car was terribly sluggish. I put the stock airbox on after I found one and last time I was there the heat didn't phase the car as bad.
As for the overheating part, it may relate back to maintenance. When was the coolant flushed last? Any leaks? etc. maybe your thermostat is starting to stick?
