Cheap Racing Seats for Tall Drivers
Old Sep 26, 2017 | 07:32 PM
bootyscoper's Avatar
bootyscoper
Default Cheap Racing Seats for Tall Drivers
Just got my Z on September 12. It's a 2004 Gray Enthusiast, only 62,000 miles I absolutely love it. But, I am 6'4-6'5. I fit well but I would be a lot more comfortable if I was an inch or two lower to the ground. I was looking at aftermarket seats and searching through the forums and people have suggested what route to take but nobody has clarified what works the best for the price. So I need your guys help on your experience on racing seats what can make the seat as low as possible and how can I do this by not spending a lot of money? Thanks!!
Old Sep 26, 2017 | 08:50 PM
Shoomakan's Avatar
Shoomakan
I'm 6'7 (200cm) and I feel your pain.
I guess you could go to a workshop and have the stock seat rails lowered or modified? If you want aftermarket seats there are plenty to choose from, and since you can buy specific brackets for them I'm sure you can find something to meet your needs.
Old Sep 27, 2017 | 06:37 AM
dkmura's Avatar
dkmura
General & DIY Moderator
Welcome- "cheap" and "racing seats" do not go together. If you want a lower seat position, the best route is to get some custom seat rails built, but that'll cost $$. Cheap out on this and you'll also compromise your safety, so proceed with caution.
Old Sep 27, 2017 | 06:58 AM
KingBaby's Avatar
KingBaby
Hardest Setting
Currently doing this...will post pics soon
This approach should a be a good gain of two plus inches.
The stock seat bracket slider can have it's mount cut clean off leaving just the slider. Then an aftermarket bracket can be welded to it!
Also the adjustments on the OEM seat have bump stops. Trimming a tooth or two off them should few up some more degrees of adjustment!
Old Sep 27, 2017 | 07:45 AM
bootyscoper
Sounds good! I might do the same, Pictures would be fantastic! Thanks man
Old Sep 27, 2017 | 08:56 AM
WYZIWYG's Avatar
WYZIWYG
Corbeau seats aren't terribly 'expensive' compared to the BRIDEs that most owners go with. And I know when I bought mine they offered to shave an inch or so off the base to lower your position in the seat since they aren't adjustable like the OEM 350Z seats they replace.
Old Sep 29, 2017 | 11:25 PM
KingBaby's Avatar
KingBaby
Hardest Setting
Default OEM Seat adjustment mod
Magic ! You'd think someone would document this !
trimming the adjustment a few mm and you get about an inch drop of the seat base. With the seat back reclined that send the helmet/skull of the driver down and back so overall more clearance !
The circle to the left is the rear adjustment, it's the only one I trimmed .
Do not trim the bolt
Only massage the the groove
Old Oct 10, 2017 | 12:23 AM
Shoomakan's Avatar
Shoomakan
I'm not that great at visualizing, could you elaborate on what you've done? Massaging the fitment of the bolt lowers the seat base, thus giving my head more clearance for the same amount of seat back tilt?
Old Oct 10, 2017 | 07:16 AM
KingBaby's Avatar
KingBaby
Hardest Setting
EDIT:
the pic is taken with the seat upside down, so your looking from the bottom.
Basically you would massage the grove that hits the bolt stop.
Seen in the light red circle that groove gives more adjustment.
So once you deepen the groove you'll have more turn in the adjustment **** thus giving a lower seat position and with the seat reclined positioning your head down and back !
Old Oct 10, 2017 | 09:08 AM
bootyscoper
EDIT:
Is this the base model? I have the enthusiast which is electrical adjustment so would this work for me or no?
Old Oct 10, 2017 | 10:30 AM
KingBaby's Avatar
KingBaby
Hardest Setting
These are nismo cloth seats basically base model seats!
you should look into trading those seats asap
visit the link below
https://store.windingroad.com/mobile...seats-c52.aspx
Old Oct 10, 2017 | 05:08 PM
bmccann101's Avatar
bmccann101
you can have the driver seat mounting tabs dropped dramatically as well, grind out the locating pin, cut and re weld new bolt tabs , and I dropped my oem seats drastically.
