Average oil pressure for a 2003 Nissan 350z?
Old Oct 29, 2017 | 10:03 AM
gfish618's Avatar
gfish618
Default Average oil pressure for a 2003 Nissan 350z?
Hi Im brand new to the forums and I just purchased a Z yesterday and have been trying to learn stick shift for the first time on it.
I've noticed that consistantly the gauge will stay at around 120 for oil PSI so I'm just wondering if this is normal. It will be sometimes lower than that and then rise when accelerating.
And just this morning, after starting it up and letting it warm up for a while I took it for a drive and it stayed at a solid 120.
My dad insists its the way im driving it since im still trying to get used to the clutch but I'm not too sure because I've read about the sensors going out.
Thanks!
Old Oct 29, 2017 | 10:05 AM
CK_32's Avatar
CK_32
oil pressure guage should range from 10-30 on idle. Anything over 60 should be under acceperation only.
Make sure you have the correct weight oil and filter and your oil system is working properly.
But there is no standard, mine averages 30 idle and 80 under acceleration. My friends use to idle at 10 then go up to 100 on acceleration. Z's oil pressures are all over the place.
Old Oct 29, 2017 | 10:15 AM
bealljk's Avatar
bealljk
well...sorta...if you want to call the FSM specs a standard than there is a standard.
I'll be the first to admit if my pressure is close to what OEM specs than I call it good - many factors that influence
Page LU-7
engine speed, under no load, at operating temp ...
idle - 14psi
2k rpm - 43psi
6k rpm - 57psi
Old Oct 29, 2017 | 10:40 AM
CK_32's Avatar
CK_32
Yea I just meant there is no standard when you literally go to a meet and ask everyone what their pressures are.
Like I said 5 co workers have Z's and almost none of us had the same pressures. So you can't just go off OEM specs and say NO MY Z IS BROKEN!!
We kind of wonder how inaccurate these OEM gauges are honestly. Cause aside from one kid all our cars and motors are in good shape and work fine and don't burn oil like crazy. But then again the kid who burnt oil had the highest pressures. Which might be why it's getting into his intake mani.
Old Oct 29, 2017 | 11:10 AM
Atreyu'z 350's Avatar
Atreyu'z 350
OP, what is the mileage, and what weight oil are you running?..
Old Oct 29, 2017 | 11:14 AM
bealljk's Avatar
bealljk
I know what you meant! and, yea...taking readings off the OEM center gauge is a whole 'nother animal!
Old Oct 29, 2017 | 03:00 PM
dcains's Avatar
dcains
Just replace the sender. But, but be very careful not to over-tighten it, or you'll damage the threads in the upper oil pan. Also, buy an OEM sender from a dealer.
Old Oct 31, 2017 | 08:32 AM
gfish618's Avatar
gfish618
So it turns out actually that the gauge is bad actually, when I flick it, it jumps back down to around 60 when accelerating and 30 when idling. The car is at almost 90000 miles and runs royal purple.
Old Oct 31, 2017 | 02:07 PM
CK_32's Avatar
CK_32
Oh Jesus!
Stop buying that over priced crap and get real engine oil.
Old Oct 31, 2017 | 03:47 PM
Spike100's Avatar
Spike100
Apparently (based upon your new information) the gauge is "sticking."
Replace the gauge and you're good.
Old Oct 31, 2017 | 04:29 PM
gfish618's Avatar
gfish618
Alrighty will do and is royal purple actually bad? The owner said hes had it on royal purple ever since he bought it so I know almost nothing about it
Old Oct 31, 2017 | 05:42 PM
bealljk's Avatar
bealljk
Oil selection is personal preference
but I agree with CK in that it's overpriced - theres many worse things you can put in your car though...
Old Oct 31, 2017 | 06:07 PM
CK_32's Avatar
CK_32
Like Beal said it's mostly personal preference but when i was in college auto shop we went over oils and our instructor showed us studies and testing done on royal purple and how average of oil it actually is compared to "normal" priced oils. It actually broke down REALLY FAST.
Basically from all the testing mobile and Castrol were the top oils. And standard synthetic Pennzoil yellow bottles which I used at the time was one of the absolute worst.
Look into legit tests and see the difference. But the only thing I put in my car now is either GTX Or Mobile premium synthetics.
I'm not saying you should use those 2 but all I will beg of you is don't use royal purple, or standard penzoil yellow bottle. And always use synthetic. Everything else just go off what you feel is "better". But those are legit the worst.
Old Oct 31, 2017 | 06:22 PM
bealljk's Avatar
bealljk
Ive heard good things about castrol and Ive been using valvoline syn...
Old Nov 1, 2017 | 08:56 PM
Theminatar's Avatar
Theminatar
I use Castrol because of this chart: https://my350z.com/forum/engine-and-...-and-info.html
And it's cheap, RP isn't bad, just way overpriced.
Old May 29, 2022 | 10:43 AM
Orn's Avatar
Orn
Default Oil pressure stuck high on gauge
The pressure gauge fails "high" when the oil pressure sending unit fails. Replace the sending unit and everything should go back to normal on the gauge. The cost is about $45.
Old May 29, 2022 | 02:51 PM
travlee's Avatar
travlee
Master
5 year dead thread
Old May 29, 2022 | 04:41 PM
jhc's Avatar
jhc
General & Tech Moderator
1st ever post, trying to help. We could use more like that... ; )
