Blown Up??
Old Feb 25, 2018 | 06:52 PM
Kevin Skene's Avatar
Kevin Skene
Default Blown Up??
Hey. I have a DE with 129k. 6 speed.
I was out beating on the car and found out the hard way that the fans never kicked on..
Facts:
-No codes
-Compression Test Results (Engine ran for a minute tops, WOT)
Cylinder 1: 120
Cylinder 2: 105
Cylinder 3: 115
Cylinder 4: 115
Cylinder 5: 105
Cylinder 6: 120
-No coolant in the oil or oil in the coolant
Overheated, boiled coolant out of the overflow tank, and felt like i was driving with the brakes on after that (very sluggish and had resistance). Also very difficult to start after the occurrence.
-Rolls perfectly fine in neutral and had plenty of oil.
I'm going to go ahead and compression test it and go through the basics to determine the issue. I'm new to VQ's so just wanted to check and see if any of you have experienced something similar with yours. Thanks.
Old Feb 25, 2018 | 08:50 PM
CK_32's Avatar
CK_32
Check your coolant and oil. See if they mixed.
You probably blew your head gasket and possibly warped a head.
Old Feb 25, 2018 | 10:42 PM
Kevin Skene
COOL will check tomorrow
Old Feb 26, 2018 | 12:21 AM
bealljk's Avatar
bealljk
yeah...leak-down and compression test for sure. Might be worth the $30 to have blackstone test your oil content too. have you done coolant/radiator work on the car recently?
Old Feb 26, 2018 | 04:09 AM
travlee's Avatar
travlee
Master
Old Feb 26, 2018 | 10:22 AM
Kevin Skene
Yeah, new upper oil pan and new radiator. I jacked the car up to probably a 25 degree angle to bleed air out of the system. Didn't seem to be leaking anywhere except the overflow reservoir itself. Oil was topped off as well. No leaks anywhere. Should be noted that I had to take off the upper oil pan twice. The first time I replaced it, one of the half moon seals against the transmission wasn't seated properly and leaked into the trans bell housing. Maybe a quart went in there and drained out of the 'hole' at the bottom where you'd pry the pan off the block.
Old Feb 26, 2018 | 10:24 AM
Kevin Skene
Originally Posted by travlee
**** me right?
Old Feb 26, 2018 | 10:33 AM
dkmura's Avatar
dkmura
General & DIY Moderator
Surprised you didn't notice the water temp gauge was being pegged while you were out "beating on the car". Also, did any CELs show up? And have you scanned for any codes?
Old Feb 26, 2018 | 10:40 AM
bealljk's Avatar
bealljk
No codes DK but should have noticed the temp gauge.
OP, have you ever replaced head gaskets?
Old Feb 26, 2018 | 10:51 AM
Kevin Skene
I'm surprised as well. I didn't have my scanner on me when it happened, but after towing it home i plugged it in and had no codes. I'm going to head over to the garage in a few hours and get some details.
Given that this motor has 140k, i've already accepted picking up a new imported motor this week. Start fresh with 40k miles and take my time getting this motor rebuilt right.
I'll report back later today.
Old Feb 26, 2018 | 10:57 AM
Kevin Skene
Not on a VQ. Sooooooooooo excited to pull the motor. I'm ambivalent about the whole thing because it's not my daily, but I love it way more than my BRZ.
Old Feb 26, 2018 | 11:34 AM
bealljk's Avatar
bealljk
If it was me I'd just rebuild your current motor and/or buy a built block ... I wouldn't import anything, you're just asking for trouble...
Old Feb 26, 2018 | 12:26 PM
Kevin Skene
Why not both! There are a few shops here in Los Angeles that sell imported motors. Compression tested, under 60k miles and warrantied.
Just getting to the shop now. Maybe it’s nothing after all
Old Feb 26, 2018 | 12:27 PM
JCat's Avatar
JCat
Old Feb 26, 2018 | 01:00 PM
Kevin Skene
Old Feb 26, 2018 | 01:12 PM
travlee's Avatar
travlee
Master
I think its DRT (old paramedic term for dead right there)
Old Feb 26, 2018 | 01:44 PM
Kevin Skene
RIP
Old Feb 26, 2018 | 01:47 PM
Kevin Skene
Cylinder 1: 120
Cylinder 2: 105
Cylinder 3: 115
Cylinder 4: 115
Cylinder 5: 105
Cylinder 6: 120
Normal on these cars is 140...right?
The passenger side valve cover has oil on it around the spark plug tubes. Though the tubes appear to be clean inside and can't find where the oil is coming from.
Old Feb 26, 2018 | 02:09 PM
travlee's Avatar
travlee
Master
At least you are beung a good sport about and not getting butthurt like some other new members
Old Feb 26, 2018 | 02:21 PM
Kevin Skene
Things fall apart, they break, that's life.
No oil in the coolant, no coolant in the oil. Oil looks cloudy, but no coolant separation.
Hmmmmmmmm
