Help about after plenum spacer installation
Old Mar 26, 2018 | 06:26 AM
gotty's Avatar
gotty
Default Help about after plenum spacer installation
Hi guys,
I've just added a Motordyne 5/16" plenum spacer to my 350z 2004. Now I get 4 ECU errors all about air intake.
I just wanna know, is it normal after changing the plenum, or I probably have some loss of air somewhere and I need to fix it?
Thank you
Old Mar 26, 2018 | 06:44 AM
jcrick's Avatar
jcrick
What errors are you receiving?
Old Mar 26, 2018 | 07:00 AM
RedBullRR's Avatar
RedBullRR
Looks like you did 1 or 2 things.
Did not tighten plenum enough so you have a air leak.
Or You didnt plug one of the hoses back in. Again Air leak.
Hope that helps.
Also a good idea to reset your ECU after this kind of install.
Old Mar 26, 2018 | 07:04 AM
jhc's Avatar
jhc
General & Tech Moderator
Originally Posted by gotty
Hi guys,
Thank you
For me, yes.
I assembled mine with gaskets and torqued to spec, idled like ****. I put a vacuum guage on to discover major leaks. Took the whole thing apart and siliconed every edge. Reassembled and boom, no more leaks.
Old Mar 26, 2018 | 07:30 AM
gotty's Avatar
gotty
unfortunately I can read the error on this weekend, since I'm far for job, but they were all related to air intake system. Btw I'll write here when I'll have my car again.
Old Mar 26, 2018 | 07:31 AM
gotty's Avatar
gotty
Hope that helps.
I tighten them at the torque they say to do.
And I'm pretty sure to have replugged all hooses.
How can I reset the ECU?
Old Mar 26, 2018 | 07:34 AM
gotty's Avatar
gotty
Originally Posted by jhc
For me, yes.
Ohhh I see. I have leaved the original gasket inside, do you suggest to remove it and use only the ones on the spacer?
Old Mar 26, 2018 | 07:50 AM
jhc's Avatar
jhc
I reused the original gasket on bottom and the one from the kit on top.
^^^ Make sure ALL hoses are connected, including the 1 under air intake snorkel.
Old Mar 26, 2018 | 09:45 AM
Cracka350's Avatar
Cracka350
I have that spacer as well. Kept the stock one in there too since it's still good. I didnt have any errors after install so crank it down and check your hoses.
Old Mar 26, 2018 | 02:42 PM
Atreyu'z 350's Avatar
Atreyu'z 350
Remove the negative battery terminal, turn on your headlights, then get inside the car and pump the brakes 15 times.
Old Mar 26, 2018 | 04:28 PM
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
You most likely have air leaks.
Might have also fumbled one of those spacers for the bolts in the middle of the plenum.
Old Mar 26, 2018 | 11:29 PM
gotty's Avatar
gotty
Thanks to everybody guys!!
I'll check everything on this weekend, then I'll let you know the results!
Old Mar 28, 2018 | 10:26 AM
tmdz's Avatar
tmdz
Did you touch the throttle body? Cause its really tempting to do...
Old Apr 1, 2018 | 02:54 AM
gotty's Avatar
gotty
Eheh, no I was able to resist it ;-)
Old Apr 1, 2018 | 02:59 AM
gotty's Avatar
gotty
Weekend Update: Hi guys, the errors seem to be gone after I cancelled them before driving again my car, most probably as written into instructions the mod needs some driving to fix and seal complitely (in this case I feel very lucky). Anyway, just to be sure that everything is ok, is there somebody that can check, via OBDII and with a plenum spacer installed, the value of vacum sensor because datas before and after are different on my car.
Thanks to everybody and Happy Easter!!
Old Apr 4, 2018 | 11:24 PM
gotty's Avatar
gotty
Default Final Update
Hey guys just for let you know, I've just tighten a little the bolts of plenum and the error disappeared, then I did an ECU reset and now the car works really fine, thanks to everybody!
Moe747
Feb 29, 2016 07:51 PM
maXmood
Apr 24, 2015 11:38 AM
QuadCam
Mar 15, 2007 06:03 AM
etang789
Mar 14, 2005 02:38 AM
S350Z
Mar 13, 2005 06:24 AM
