Tuning Options
So tuning, I don’t know jack squat about it. I mean I get the gist of it but overall not really. So I’ve got some questions about it.
What does it do?
What do I need to install one?
What is a good company/tuner that isn’t to expensive?
Are there different types of tunes?
Any other information would be helpful. Thanks.
What does it do?
in a nutshell ...
a tune will optimize your engine & modifications for your specific environment
different kinds of tunes will require different hardware - generally speaking a reflash will reprogram the OEM ecu and there is no hardware to buy (maybe a cable to connect to the car??). Piggyback tunes add a physical computer type box that (literally and figuratively) attached to the OEM ECU. A standalone replaces all-together the OEM ecu.
Look into Uprev (reflash), Haltech(piggy back & stand alone) and Link (piggy back and standalone)...those are the major players in our world.
I don't like the greddy Emanage, UTEC is alright, avoid any 'chip' type plug-ins. Uprevs, haltech, Link ... choose one from that list. Likely for you, Uprev is your best bet.
Many different types of tunes based on what you did to the car and what you use the car for...but mostly optimizes your setup.
too much information out there for a single thread ... research what others have done, find someone who has a build like yours and mimic what they did (don't reinvent any wheels)...
I really learned quite a bit about tuning and my haltech with High Performance Academy - heres a free set of tuning basics ... check it out
https://www.hpacademy.com/courses/ba...g-fuel-tuning/
in a nutshell ...
350Z/370Z Tech Moderator
One of the things I've found with any type of aftermarket tuning is the software is only as good as the person tuning it. What I mean by this is that it helps tremendously to actually have the car on dyno (hence "dyno tune") and any changes can be monitored and tailored to an exact spec and power level. Shops that do this kind of work charge anywhere from ~$600-1000 depending on what else has been done to the car.
That said however, anyone can learn to use the tools; not terribly difficult but again, without anything but seat of pants to base changes on, not quite an exacting science.
Most mentioned here on forum - as was already mentioned above - Uprev and Haltech with a smattering of others here and there. I only mention it again to add credence.
Honestly, while it can help some in stock configuration, it's best when used with deep breathing modifications (in/out, exhaust/intake, FI, cams, etc.)
consider cost too ... uprev will be your most economical at/around $700. With $2000 worth of intake/exhaust mods you'll pickup 30hp after your tune. Is 30hp worth $2700??
haltech is probably in the $1000 to $3500 range and Link is (I think) $1500 to $4000 ...
Just keep you eyes and ears on peoples threads and see what theyre doing with their setup...
Alot of people are using Uprev on NA and FI builds, a few using haltech on FI builds and I know of only one person using Link (on this forum).
Did you watch those videos?
Interesting what you learn if you hang on to your car long enough. I always thought tunes were only useful after you began doing basic engine mods?
[exhaust, CAI, headers, etc...]
