battery cable too hot
Old May 10, 2018 | 03:46 PM
rangersraven's Avatar
rangersraven
Default battery cable too hot
my son has a 2005 350z, and the positive battery cable is way too hot. any ideas whats heating it up? so hot, will burn the fingers. he said the negative cable too hot as well. also, the car wont start, lights and gages work. Starter doesnt even try to bust off. Have checked battery, has good charge.
Old May 10, 2018 | 05:57 PM
liven Z life's Avatar
liven Z life
Sounds like a winding or something starting to short to ground. Is it hot all the time or only when you try to start the car? Or when the keys in the on position and not trying to start?
Old May 14, 2018 | 03:08 PM
tmdz's Avatar
tmdz
Battery cables heating up mean(s) something is messed up with the wiring. Usually a fuse or fusible link will blow if something is reversed but i guess it’s possible someone put a 40amp fuse in a 10amp breaker...
Old May 14, 2018 | 05:47 PM
achampagne's Avatar
achampagne
If its too hot, then don't touch it.
Old May 15, 2018 | 12:22 PM
zakmartin's Avatar
zakmartin
Factory or aftermarket cables? Are there any aftermarket accessories like amplifiers, etc tapped into the main cable?
Old May 17, 2018 | 05:46 AM
Dr. Venture's Avatar
Dr. Venture
You said the starter won't start? it's probably Starter Sol is stuck on creating the cables to get hot. Probably needs a new starter. I've had this happen on a customers older toyota....touch the starter if you can and if it's hot to the touch as well then that is your issue. Otherwise....there is a short somewhere.
Old May 22, 2018 | 09:22 AM
FlashEvolution's Avatar
FlashEvolution
High resistance or high current somewhere. I would check your grounds for corrosion/broken wires and also check your fuses to ensure nothing is blown/melted or replaced with a higher amp fuse. Also, a faulty starter that is drawing excessive amount of current can cause your no start/hot cable condition.
Old May 30, 2018 | 05:40 AM
rangersraven
hubby and bro-im-law found out problem. engine locked up. they got it to start, ended up with pieces of piston and engine block in the yard. this car is waiting for new motor. but son went and got a 2011 370z. thans yall for the replies
k1653d
94
May 19, 2015 11:30 PM
mdracer76
Mid-Atlantic
Jun 21, 2005 06:11 AM
