Popping 350
Old May 3, 2019 | 05:56 PM
Bradley Carver's Avatar
Bradley Carver
Default Popping 350
Alright so I’ve got a popping sound coming from the rear area of my Z and it sounds like a tire is popping, axles aren’t in bad condition, diff fluid is good. There is a little play in the back left axle but I don’t think enough for it to pop the way it does. Just trying to brainstorm and figure it out cause everything seems tight underneath and it’s getting frustrating figuring out what it is.
Take note it happened after I done a couple burn outs so I kno I personally done it and I have the money to fix what ever it is just can’t find the issue.
Old May 3, 2019 | 06:14 PM
travlee's Avatar
travlee
Master
Is there black jizz from the differential bushing on the subframe?
Old May 3, 2019 | 06:16 PM
Bradley Carver
There is a little bit, but I feel like it was there before I got the car which I guess wouldn’t matter I just made it worse I’d say. You thinking it’s the differential bushings ?
Old May 3, 2019 | 06:20 PM
travlee's Avatar
travlee
Master
Either that or axle pop....aka the half shafts need greasing ......which is easier to fix than diff bushings
Old May 3, 2019 | 06:22 PM
Bradley Carver
Well I’d rather go ahead and replace all the bushings cause the center one is pretty bad. But I will try greasing it up and see if it helps.
Old May 3, 2019 | 06:28 PM
travlee's Avatar
travlee
Master
It would be best eventually, but they aren't fun. Try the cheap easy fix first
Old May 3, 2019 | 07:36 PM
icer5160's Avatar
icer5160
Depending on the severity of the "pop" it could also be the common axle clicking. There's a thread HERE the details the TSB fix.
-Icer
Old May 3, 2019 | 09:08 PM
tmdz's Avatar
tmdz
I actually enjoyed replacing the diff bushings. It’s a kind of a long process but not super complicated. The worst part for me was the axle nuts. Loaner tools available at AutoZone, etc.
The little kid in me loved burning out the ears...
thReeFiFtee
Dec 1, 2005 04:00 AM
JCat
Feb 15, 2005 12:13 PM
